Overheating in traffic... Should I worry?
Otherwise, I'll stand by my original thought, that the OP should figure out how to purchase and correctly install an electric fan setup.
Corvette 1973 big block 454 fan and clutch.
I got the cooling system checked, and the guy installed a proper fan with a clutch.
Took the car for a spin in city traffic on a hot summer day (ambitious, I know), and it worked like a charm - water temp went to 210 and stayed there, no overheating.
Then when I got to the car event, I switched the engine off immediately and learned the hard way that you should let the car cool off before doing that.
So the car is fixed, but I'm still an idiot - any advice on how to handle heat properly?
I've already heard:
- Turn the heater on high - this will help move some heat away from the engine
- Open the hood while leaving the engine running
- Keep distance to the car in front, so you don't get their hot exit air in your radiator
- While stopped, hit the gas to get the fan spinning (I would think this would make the clutch disengage the fan?)
Thanks for all the friendly and helpful advice I received here, very much appreciated. Gave me clues and confidence to go about solving the problem.
There are numerous threads regarding this issue and many things that you can do to help prevent heat soak from occurring.
Put a heat shield or spacer between the carb and intake manifold and make sure the return line between the carb and fuel tank is hooked up and operating.
Add vents to the hood to allow the hot air trapped in the engine compartment to escape.
Add a heatshield between the starter and exhaust or upgrade the starter and solenoid.
These are only a few, so do some research and you'll find many others.
I think you are not out-of-the-woods-yet. Like others have said, somethings still not right.
Looks like Bubba installed a EBay aftermarket clutch fan with Ace Hrdwr penny washers / nuts.
I would be concerned about that dismounting and going through your hood!
Also, can you turn the fan easily with engine off?
To me, 210* would put me on the side of the road questioning what's going on. Mine runs 180* all day, occasional 200* with an all stock system.
That list of four chores to do (post 91) is for a emergency situation to get a overheated vehicle home. You should NOT have to do this every time you take it for a drive.
If the car is at 210, and I switch the engine off, the coolant no longer circulates, and I guess the coolant which was in the engine will boil then?
The puke tank exchanges fluids with the radiator fine - does that mean my radiator cap is working? I guess if it's broken and stuck open, it would happily puke, but the system would never be under pressure (and hence boil around 210)? Did I understand that right?
Why did you ask whether I can turn the fan easily with engine off? I assume this is how it should be (but don't know)? I'll try over lunch and get back here.
Fun fact: I tried putting on the heater, but it doesn't work (only the defroster, and that's not much help...). So I guess I'm on to fix that.
Something isn't right there.
