Overheating in traffic... Should I worry?
Old Jun 28, 2021 | 09:56 AM
  #101
interpon's Avatar
interpon
Originally Posted by Mr D.
That fan clutch mounded to the WP pulley looks weird. Why are the nuts and washers hanging over the side of the fan clutch?
i found out they all come with cheesy lock washers..and that universal slot does not allow the washer to sit flat..
Old Jun 28, 2021 | 10:23 AM
  #102
Mr D.'s Avatar
Mr D.
Ran back through this thread today and just wanted to add;
There are only two things in life that will make me run for the hills faster than Jesse Jackson chasing a $20 bill and that's snakes and flex fans. Flex fans always scared the crap out of me, spinning razor blades.
Old Jun 28, 2021 | 07:15 PM
  #103
derekderek's Avatar
derekderek
razor blades less of a threat. not enough inertia to be truly spectacular.
Old Oct 2, 2021 | 04:04 AM
  #104
mlauritsen's Avatar
mlauritsen
Thanks everybody for your advice and help, very much appreciated.
I have now been enjoying the vette over the summer, on long drives, stopped in traffic, bumper-to-bumper stop-and-go, and everything is fine.
Then a couple of weeks ago, I discovered a leak from the radiator. Both sides. Just a gentle drip, nothing dramatic, but enough to need a new rad.
Who was it that said that "on a 50 year old car, things break just because?" :-)
I checked all the hoses, and they're fine, so I really need a new one. Which means another big order across the pond. Always nice to have an excuse to order some other stuff...
With the help of my local garage guy, we tried to pour in some "Radiator Fixer" liquid, but that did nothing, and we had some fun with backpressure and lots of coolant spilling everywhere. Good times.
Anyway, car is running nice and cool, I occasionally add a bit of water (the constant leaking adds up), but it's all good.
Old Oct 2, 2021 | 11:29 AM
  #105
wadenelson's Avatar
wadenelson
Default Treatise on Diagnosing Corvette Overheating
Some of you have already seen this, obviously some have not. (hosted on Reddit)
ALL diagnosis of Corvette overheating MUST begin with pressure testing the cooling system. If it isn't holding pressure, then all the electric fans and Water Wetter and, and, and, and, in the world isn't
going to cure it. Key is don't lie to yourself; if that pressure tester needle moves AT ALL in 30 minutes, you've got a pressure leak. Find it and fix it.
Order a
Stant pressure test kit Stant pressure test kit
today. Best $80 you'll ever spend.
A single drippy hose clamp is all it takes.
It works like this; if your cooling system is holding pressure, you almost can't do anything wrong. Car just doesn't overheat. Hot days, cold days, uphill, downhill, stuck in traffic, 70mph
If it isn't holding pressure, you can't do anything right. No pusher fans, additives, sealers, shrouds, timing or mixture changes, thermostats, turning the heater on, anything will fix it.
Do NOT remove the thermostat or run a 160F thermostat attempting to cure your overheating. Reportedly, you will lose gas mileage, power, AND probably foul your plugs.
If you don't have all the foam pieces FORCING air through the Corvette radiator, and not over it, around it, under it, order a kit and install it.
A 50/50 mix of distilled and coolant is all you need. PLUS a working radiator pressure cap, and overflow bottle/hose that IS NOT CRACKED OR LEAKING.
Quit staring at your temperature gauge all the time! Quit making excuses for it: "Well it only overheats WHEN...... "
Get your cooling system sealed up and start enjoying your Corvette!
Old Oct 11, 2021 | 07:01 PM
  #106
bigvette1's Avatar
bigvette1
I have a 73 BB and cooling was an issue from day 1 especially in slow traffic or stops signs. i improved the cooling with:
- Either a flow cooler or Stewart stage 2 waterpump
- 180 degree T-Stat
- Water Wetter
- Flush radiator thoroughly
- Ck timing, try advancing to at least 10
- Make sure all seals around the shroud are in and closing extra air.
Better but not beaten.
In the end I swapped out the copper and brass radiator for an aluminum. Presto problem solved.
Old Oct 11, 2021 | 08:05 PM
  #107
68/70Vette's Avatar
68/70Vette
FWIW: I've used pure ethylene glycol in my 1968 since ~1974. Pure ethylene glycol in my 97 Tbird DD. It boils at about 350 degrees F so the cooling system is never pressurized. No corrosion, particularly with aluminum radiators.
Old Oct 12, 2021 | 11:26 PM
  #108
7T1vette's Avatar
7T1vette
Bigvette1...
You didn't list "hook vacuum advance can to manifold vacuum ONLY. Having ported/timed vacuum on that can...or having NO vacuum advance at idle will make it almost impossible to run cool.
