Breakerless ignition bad?
Old May 15, 2021 | 01:56 PM
JBrooke825's Avatar
JBrooke825
2018 C3 of Year Finalist
Default Breakerless ignition bad?
On my way to the first car show this year all of a sudden the car started to
lidle very rough and low. I turned around and came home to have a look.
I pulled each wire off the cap and found out I only had spark on 5 plugs
5,3,6, had no spark. I guess the 10 year old petronics unit must be bad.
how long do these things last and which one is the right on to buy
thanks for your help. 69 427/400 . It was running great earlier today.
Old May 15, 2021 | 04:12 PM
7T1vette's Avatar
7T1vette
I doubt that the Pertronix is the issue. When those go bad, ALL plugs fire the same way....or not at all. More likely a distributor cap issue.
Old May 15, 2021 | 05:21 PM
JBrooke825's Avatar
JBrooke825
Could be but the cap and rotor are only a couple of months old. With copper contacts. I put the old ones
back on and had the same 3 dead towers. The petronics unit was new in 2011.
Old May 15, 2021 | 06:05 PM
dan1495's Avatar
dan1495
2016 C3 of Year Finalist
How about trying a set of points and a condenser to see if it makes a difference?
Old May 15, 2021 | 06:30 PM
Mrvettenick's Avatar
Mrvettenick
Spark comes from the coil, and is triggered by the control unit. The only thing that's consistent are the wires Why don't you swap wires from a cylinder that has spark with one that doesn't?
Old May 15, 2021 | 06:32 PM
Yadkin's Avatar
Yadkin
The Pertronix doesn't know which cylinder it is firing to. Check your plugs, wires, cap, rotor.
Old May 15, 2021 | 08:04 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Those 3 dead cylinders are three in a row on the firing order and the cap. I agree with 7T1vette. I'd look at the cap.
Old May 15, 2021 | 10:58 PM
7T1vette's Avatar
7T1vette
I have seen dist caps that were mis-machined and the contact surfaces were not "circular" ...or at least, off-center. Some contacts would make connection, some would not. Another possibility is some bad bushing wear in the distributor shaft. Rotor contact and locator pins mis-positioned??
Old May 16, 2021 | 06:52 AM
JBrooke825's Avatar
JBrooke825
I was thinking about that but the resistor wire has been cut down underneath in the harness.a
and I pulled the wires at the cap. Not down at the plug. Thanks again for your suggestions.
maybe I will order another new cap and rotor and try that. I just don’t know how they would all
of a sudden go bad. There only 6 months old.
Old May 16, 2021 | 07:04 AM
JBrooke825's Avatar
JBrooke825
4 has spark though.
Old May 16, 2021 | 07:08 AM
augiedoggy's Avatar
augiedoggy
Those pertronix modules would fail all the time in the VW forum.. Its possible.
Old May 16, 2021 | 01:24 PM
7T1vette's Avatar
7T1vette
Are you CERTAIN that the distributor cap is installed completely (in the detent slot) and correctly?
Old May 16, 2021 | 03:04 PM
JBrooke825's Avatar
JBrooke825
Yes it is ,this happened on the road. It’s been fine. I’ll check it again. Thanks
Old May 16, 2021 | 03:30 PM
JBrooke825's Avatar
JBrooke825
Looks like I found it. That little magnet was stuck on the inside of the shielding
Old May 16, 2021 | 06:07 PM
69427's Avatar
69427
How did one lost magnet manage to kill three cylinders?
Old May 16, 2021 | 06:12 PM
CanadaGrant's Avatar
CanadaGrant
On the Pertronix II the only thing that holds those magnets in place is that circular piece of clear tape. When the tape fails the magnets start to drop out. I use a Pertronix III on my 69 as it no longer has this trigger system or the failures because of it. I had one fail after 6 months of use when the tape started to come off and release the magnets which just fall out the bottom.
Old May 16, 2021 | 08:51 PM
JBrooke825's Avatar
JBrooke825
They are all glued in. The tape just covers them.
To Breakerless ignition bad?
Old May 16, 2021 | 08:52 PM
JBrooke825's Avatar
JBrooke825
You tell me. What else could it be.
Old May 16, 2021 | 09:14 PM
Yadkin's Avatar
Yadkin
I never liked that Pertronix stuff, and I only went as far as using one of their ignition modules (it failed).
For my 81 I have a Duralast Gold (Autozone) HEI but replaced the module with a GM unit, and keep the Duralast module in the my emergency kit along with two screwdrivers to replace it while on the road.
Old May 16, 2021 | 09:24 PM
augiedoggy's Avatar
augiedoggy
I keep a spare HEI module too... had 2 fail on me in 6,000 miles... beefed up the wiring to the HEI and ironically after the last advance auto one failed I used a middle of the road ebay replacement a few years ago and all seems ok now.
I used to keep a set of points in my old vw kit car too because I didnt trust that pertronix module but it never failed on me. Used to read of failures on the samba forum all the time though. My stock 74 distributor had a very old looking functioning pertronix in it but I replaced the distributor with an hei when I replaced the engine after driving it home.
