Engine Quit while driving - Ignition?
Old May 16, 2021 | 01:08 PM
genuine1980's Avatar
genuine1980
Default Engine Quit while driving - Ignition?
I am hoping someone can point me in the right direction here.
I was driving my 69 as normal, and without any warning my engine quit.
Everything else and all electrical still works, lights, gauges, starter, etc., etc.
There is fuel getting to the carb so that is ok, wires and plugs are pretty new. I think I've narrowed it down to ignition.
I noticed the ignition coil was seeping boiling oil and a small hairline crack on the top of it, so I figured it was just the ignition coil..... swapped the ignition coil, and still it will not start.... I'm still thinking ignition, but I don't know what.
It has an MSD Blaster 2 ignition.
Again, everything else having to do with electrical on the car is still working fine.... so I don't think I blew a fusible link.
Does another ignition component usually go bad when the coil goes? Has this happened to anyone else? Is there a fuse I don't know about? Any real suggestions and/or illustrations would be great.
Old May 16, 2021 | 01:44 PM
7T1vette's Avatar
7T1vette
Your problem is related to one (or more) of the following: fuel, air, or ignition. My bet is on ignition, unless your fuel pump just flat quit.
Old May 16, 2021 | 01:54 PM
ddsmith60's Avatar
ddsmith60
Okay, I have seen post that say that our car didn't have a ballast resistor installed from the factory. My 71 had one on the firewall, that when it went bad, the car acts like it wants to start when cranking it over but immediately dies when the key was taken to the run position. Look on your firewall for a rectangular ceramic looking thing with two spade connectors. If you have it, like I did you can check to see if you have 12v on one side and none on the other. If bad you can temporarily run a jumper from the 12v side to the coil and then change it out. You don't want to leave it that way though, it is hard on the points. If you don't have it then you have a resistance wire in that line feeding power when in the run position. It is possible that it is open. I would assume with all this discussion you are still running a points distributor. If you are running HEI then this is all a waste of typing. If it is HEI and you have that symptom, I would think it is you module gone south. Good luck. I will attach a link to what a ballast resistor looks like so you can find one if you have it. Standard Motor Products RU11 Standard Motor Ballast Resistors | Summit Racing
Old May 16, 2021 | 03:39 PM
Tampa Jerry's Avatar
Tampa Jerry
The ceramic block resistor disappeared in 1968. GM replaced the ceramic block with a resistor wire. If you have your stock ignition shielding, check to see if the negative wire going to the coil got chaffed by the shielding and is grounding out the engine. it does sound like your module is bad. Jerry
Old May 16, 2021 | 04:08 PM
MelWff's Avatar
MelWff
It's not too clear what ignition system you are using. You state you switched out the coil but then say you have a MSD Blaster 2 ignition.
Isnt that the name of the coil you removed?
Do you have the stock distributor or something else?
Does the distributor have points or is electronic?
Need more details on exactly what you are using.
Old May 16, 2021 | 08:14 PM
genuine1980
I have an electronic MSD ignition. The MSD box is under the front driver side wheel well. The ignition coil was an MSD Blaster 2. I believe the coil went bad because it was seeping boiling hot oil from a hairline crack on the top of it. I replaced the coil.
I still have no ignition. I don't seem to have power (voltage) to the positive side of the coil... I assume there should be.
I have no idea what else could have gone bad at the same time as the coil that it still has no ignition after replacing the coil.
Old May 16, 2021 | 09:57 PM
Yadkin's Avatar
Yadkin
You should have 12volts there while cranking, about half that with the ignition switch in the run position with a regular points distributor. Since you have an electronic distributor, there should have been some wiring modifications to make it 12 volts in run as well.
Lots of guys don't do this modification correctly. So find out what was done. Best way is to run a new #10 wire directly from the ignition switch to the coil. Normally this circuit is not fused so the wires are oversized.
Old May 16, 2021 | 10:13 PM
genuine1980
Old May 16, 2021 | 10:40 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
That box on the fender looks like a CD unit (not known for durability). It supplies a 450-500 volt pulse to the coil at the time of ignition/spark. That's the only time voltage is present at the coil.
Old May 17, 2021 | 12:18 AM
Bikespace's Avatar
Bikespace
Can you take pictures of your distributor, too? Perhaps with the distributor cap off? Show the inside of the cap, too.
If there is an electronic pickup (HEI module, Pertronix Ignitor, whatever), it is almost certainly your problem.
Old May 17, 2021 | 08:20 AM
genuine1980
SO I think you are saying that the MSD control box went bad? Does it need to be replaced entirely or is there a fuse or something that needs to be replaced?
Old May 17, 2021 | 08:21 AM
genuine1980
The car rans fine for more than 20 years... it just died without warning.
Old May 17, 2021 | 08:52 AM
Yadkin's Avatar
Yadkin
Since you have an MSD box, the ignition switch start/run should provide 12 volts to the smaller gauge red wire at the box. The larger gauge red wire at the box should go directly to the battery positive terminal.
Get a number off of the box and find the wiring diagrams for it.
Old May 17, 2021 | 10:17 AM
69427's Avatar
69427
The main point of my comment was that with a CD system you do not see 12v at the coil. Ever. CD systems work differently than inductive systems. My minor point was that those CD boxes do not typically have the same reliability and durability as inductive control modules.
Old May 17, 2021 | 11:01 AM
carriljc's Avatar
carriljc
I suggest you check the leads going to your coil. Last time I had a sudden failure like that I had an OPEN lead hidden underneath the insulating material. My OPEN was near the connections at the coil but you can wiggle along the length of the lead. If you can get the car started you can wiggle the leads to the coil to see if dies. If you cannot get the car started the use a jumper to see if the car starts to temporarily bypass the installed leads.
Old Jul 12, 2023 | 04:11 PM
Renegade44's Avatar
Renegade44
2nd Gear
I need to do this to my C5 STAT!!!! I have run down the battery multiple times from having a Bluetooth receiver in the cigarette lighter socket. So just an add a fuse should do the trick right? Anyone know if there's a video out there of this? I looked but found nothin. thanks for sharing!
Old Jul 12, 2023 | 04:57 PM
1971corvette's Avatar
1971corvette
deleted
To Engine Quit while driving - Ignition?
