Air Conditioning Compressor
Old May 17, 2021 | 11:14 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Default Air Conditioning Compressor
This may be a kinda dumb question, but thought I'd throw it out there to all the Air Conditioning experts.
Today I painted my new compressor to match it up with other accessories on my engine. I painted it with VHT Caliper paint. VHT says to bake paint at about 200° F for about 20 minutes. I would like the paint to be hard and chemical resistant. But concerned about putting the compressor in the oven for fear of destroying seals. What if I put it in at slightly lower heat for 30 minutes? Any thoughts or suggestions?
Thanks Guys.
Old May 18, 2021 | 08:09 AM
interpon's Avatar
interpon
although i do NOT see an issue with the 200f.. the reality is that mass will need to heat soak for some time to reach that temp..
if it was me i would have an iR gun handy and a heat gun and adjust as needed to be 180-200f for a minute or two around it.
that engine compartment and that compressor running will bake that paint!
Old May 18, 2021 | 08:17 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
You won't hurt the seals no more than you would hurt the caliper lips seals during hard braking where temperatures exceed 200*. I would do as directed as the paint is on the surface and will be exposed to the oven heat from the onset.
Old May 18, 2021 | 11:22 AM
7T1vette's Avatar
7T1vette
You don't need the entire compressor to be a 200*F...you only need the PAINT to be a 200*F. Just stick it in an oven and follow directions.
Old May 18, 2021 | 11:29 AM
Mrvettenick's Avatar
Mrvettenick
Engine compartment temps exceed 250 easily. That compressor will be fine.
Old May 18, 2021 | 05:11 PM
4-vettes's Avatar
4-vettes
Thanks Much for the replies.
To Air Conditioning Compressor
