I bought my dream car C3 BB 3 years ago with the intent of driving it every summer and fixing it up every winter. Still have not driven it yet! When I looked it over good I did not like what I saw. So I decided to rebuild everything. It evolved into a full frame-off $30k in parts restoration.
Oh well, I am still having fun! And it will be worth it in the end.
You bought your car for $3800??? Dude....You are so far ahead of the curve you can afford to make a few mistakes. I didnt realize yours wasnt the earlier
years. I've been going off that because mine is a 72. You do have a little more room under there to play with. If it was me, I'd wait till you have
the motor in the car to test the height and before you buy something. Start by using what you have, and then order from one of the big stores.
You'll have what you need in 3 days, or in your case just drive down to ATL and pick it up.
BTW, I've been doing this **** for over 60 years and I still need help. Anybody who says he knows everything is full of ****
S.F.
Yes, sir. The PO had it listed for $5,000 and I walked away because he refused to take cash and the banks were closed.
He called me back the next day and offered it for $3,800 not a dime less.
So I made the 2+ hour back down there to pick it up.
Yeah, I’d really like to use the intake I’ve already got, if possible.
This weeks high point...My TREMEC arrived!
Sounds like an awesome build!
Enjoy!!
Im just wanting a simple weekend cruiser for myself without taking out a second mortgage. 😬
Sorry I was wrong to be so harsh. But I was in the navy .
Ive always told people in the past that full roller motors add about $2000 to the building cost. That cost number is much higher today. You need. Longer valve stems, better springs, steel roller rockers. 7/16th ARP rocker studs, better push rods, roller lifters, and the best billet steel timing chain sets.
IDK I think many performance builds already have decent head components and double timing chains. 2 grand just to install a roller cam alone is an exaggeration IMO, Unless your just assuming everyone doing so only upgrades those other components when going to a roller.. Factory roller engines didnt need all that just because they were roller cams. My comp xe270hr retro roller upgrade was about $500... $295 for the cam shipped, $128 for the retro roller lifters from rock auto, and $45 for the howards pushrods.. $16 for the cam button and maybe $30 for gaskets. Everything else I already had from my flat tappet setup..A I know some believe there is no benefit to going roller on cams with less than 278 duration but thats simple not true from my experience. going from the vodoo 262/268 tappet cam to the com 270/276 roller cam was a pretty big jump in performance. Sorry for the condensed response... My "return/enter" key has stopped functioning a few days ago..
Longer valve stems? Never heard that before? Shorter push rods - yes.
Lastly, thank you all, once again, for putting up with us ignorant noobs 🤪 and our countless questions.
Gotta go now and count up the last 2 nickels left of my life savings after buying a vette….and collect on my wife’s promise of another ****-whooping.
Nothing to apologize for. Since I decided that I will very likely replace my FT 350 with a roller 383 next year, I have searched up all the threads I can find related to crate engines, roller cams, and 383s. This thread was just as informative as any.
Good luck. Cars are an expensive hobby, but many hobbies are. It’s also very rewording as you work through troubleshooting and solving the issues that will arise.
As valve lift goes up with roller cams the spring installed height has to go up so the spring doesn't go into coil bind at max lift.
I'm talking about lifts exceeding. 560. Larger diameter and taller springs run cooler. So your typical after market head like AFR come with. 100 longer valve stems. Both of my vette motors have. .200 longer valve stems for 2.050 installed height to accommodate over .700 valve lift
The push rods are also longer than standard to keep the valve train geometry correct
Thank you for your service!
I understand completely. I tend to be a little harsh myself. It runs in my blood!
See thats what im talking about.. I had the .100 longer valves already as well. A lot of aftermarket heads require them regardless of cam.
to me, post 105 implied that if you switched to a roller cam, then longer valve stems are required. Period. The post said nothing about valve lift > .560.
And thats a negative...The length of the valve stem has nothing to do with whether one has a flat tappet, solid or roller cam. many aftermarket heads are set up for lager lift cams regardless of type and that is one reason the stems are longer. Another is the actual head thickness if I understand correctly.. Again my point is the difference between a retro roller cam and equally sized flat tappet is the cost of the cm, retro lifters and pushrods.. the other high lift, high performance stuff is usually required regardless.
absolutely.
Also, It used to be that one took a major *** pounding when buying retro roller rockers. The price you mention in post 108, shows that is no longer the case. That’s an awesome price.
BTW, I’ll be “going roller” next year, but it will be done with a roller 383 block swap
. Another is the actual head thickness if I understand correct.
Not correct, from the valve seat to the spring seat is the same distance. Aluminum heads are milled for bigger 1.46 or so springs. Aluminum heads require spring shims to protect the aluminum
Generally people don't invest in aluminum heads to put in flat tappet low lift cams
only in gen II roller blocks with the one piece rear seal
What is the benefit of LS lifters? I just bought a GM, ZZ383 gen 2 block vortec alum heads and a roller setup. Anybody know what lifters are in here?
Part # according to the spec sheet is 17120735. Also, anyone know who actually makes the alum heads and camshaft ?
