82 FE7 Leaf Spring
Old Jul 23, 2021 | 08:35 PM
brushmor's Avatar
brushmor
Default 82 FE7 Leaf Spring
I have an 82 with the FE7 Gymkhana and I am about to undertake a rear suspension restoration. One thing that I know that needs addressed is the rear spring. It's squeaking like crazy. Given the age of the spring I am figured it be best just to replace it but I am not able to figure what's the spring rate. Since it's gymkhana it has the 9 leaf metal spring. Were the 82 9 leafs the same as the base 78-80 with the 260 lb spring rate? That seems odd to me but I've never been able to find any spring rates on the 81-82 FE7 suspension to confirm or anyone selling 9 leaf FE7 springs.
Old Jul 23, 2021 | 08:37 PM
MelWff's Avatar
MelWff
Unless it is sagging why would you replace the spring, just replace the liners.
Old Jul 23, 2021 | 08:45 PM
brushmor's Avatar
brushmor
I've thought of that but I've never seen anyone selling liners for the later C3 leaf springs.
Old Jul 24, 2021 | 12:57 PM
jb78L-82's Avatar
jb78L-82
https://www.gmheritagecenter.com/doc...t-Corvette.pdf
Gm Heritage Center ^^^^^ shows you have an 8 leaf FE7 Sport steel spring and should have the 7/16 rear sway bar as well if it is a factory installed sport spring. Only 82's with Sport suspension had the rear sway bar.
Unfortunately, the GM documents do not list the spring rate for the steel spring above, only the marshmallow composite monospring at 172 lbs, pathetically soft for any car in 1982, much less a sports car. My 78 steel 7 leaf Sport spring was 292lbs. I replaced it 35 years ago with a 360 lbs composite. I would never use steel again since steel is harsh, will sag with time, is 50 lbs versus 8 lbs for the composite and a composite at MUCH higher spring rates has a superior ride versus steel.
Old Jul 24, 2021 | 02:43 PM
brushmor's Avatar
brushmor
Thanks, jb78L-82. I had started with Heritage Center docs and as you mentioned, no mention of spring rates. I wanted to avoid going the composite route just because the steel springs make it different from the rest of the 82's and some have feel sullied for messing with the originality. The car still had the original tires when I got it two years ago! But since my goal is not to have show car but a driver I it's looking more like the composite will be the way to go.
Old Jul 24, 2021 | 03:45 PM
augiedoggy's Avatar
augiedoggy
if only someone still made a composite spring for our cars that fit without the lifted 4x4 effect....Its been about a year now since Ive seen anything available but empty promises and an everchanging backorder date..so I gave up and bought a 7 leaf steel spring myself. Since ive already been waiting for months for my l88 fresh air box ordered in may from ecklers.. I should have purchased it from ebay where at least the seller had stock and was upfront about it.
Old Jul 24, 2021 | 03:52 PM
jb78L-82's Avatar
jb78L-82
As I stated on another post today, This country is now becoming a third world nation...don't expect to get parts like we once did during the "dark years of the best economy in 50 years"...all gone now..enjoy!
Old Jul 24, 2021 | 03:56 PM
augiedoggy's Avatar
augiedoggy
Do your research if your planning on the TRW spring..LOTS of threads on them here. here is a couple.
https://www.corvetteforum.com/forums...igh-still.html
https://www.corvetteforum.com/forums...mposite-2.html
Old Jul 24, 2021 | 04:00 PM
jb78L-82's Avatar
jb78L-82
FWIW-I installed my 360 composite back in 1986 made by Vette Brakes and Products, now out of business, and even back then, the TRW springs were known for adversely raising the rear of the car above the stock height which is why i did not use a TRW spring......some things never change.....
Old Jul 24, 2021 | 04:04 PM
augiedoggy's Avatar
augiedoggy
My guess would be In reality this likely has something to do with the covid fiasco effecting production worldwide since I work for the Belgians and we get our parts for our equipment from all over the world from china to canada and we are experiencing the same production delays and shutdowns... and that if Fedex can even deliver it since they have decided to not upgrade their infrastructure even though they have been overwhelmed for over a year from the increased delivery business. Instead they charge the same rates but no longer guarantee anything... Great deal.
Old Jul 24, 2021 | 04:12 PM
jb78L-82's Avatar
jb78L-82
YES!!!! And paying people not to work...............
Old Jul 24, 2021 | 04:21 PM
augiedoggy's Avatar
augiedoggy
Yes that doesnt help as this point.
Old Jul 24, 2021 | 08:04 PM
jb78L-82's Avatar
jb78L-82
Yes that doesnt help... Who instated that stupid plan?
Hugo Chavez...LOL
Old Jul 24, 2021 | 08:36 PM
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
I know you covered this a while back many times, but I'm being lazy, I guess? Did the 360 composite spring raise your *** end up or keep it where it needs to be? Also, is the ride bouncy or firm like the FE7 ride? Thanks!
Old Jul 24, 2021 | 09:18 PM
jb78L-82's Avatar
jb78L-82
My VBP 360 spring has said exactly the same height as the 7 leaf 292lbs OEM steel spring now for 35 years...Zero raise or lift. The 360 composite was very bouncy with KYB Gas A Just Monotube gas shocks way back when I put the composite on. I eventually switched to Bilstein HD's all around, front and rear, which amounted to less bounciness (still not to my liking) and, then eventually about 12 years ago, switched out the rear ONLY from the Bilstein HD's to Bilstein Sports (30% stiffer than HD). The car currently has Bilstein Sports in the rear and HD's up front. Ride is firm but no bounce and not harsh at all....
Old Jul 25, 2021 | 05:39 AM
7T1vette's Avatar
7T1vette
Rebuilding the existing spring would be my recommendation for your FE7 car. If you don't want to mess with the spring rebuild, take the spring to a truck repair shop and ask them to do it. They should have all the equipment an know-how to get that job done well. If you want to purchase 'replacement' liners ahead of time, the shop should have no trouble with that. It would be nice [but unusual] for a repair shop to NOT charge you a premium because it is for a Corvette..... But, this spring rebuild is only going to happen once in the life of the car.
Old Jul 25, 2021 | 08:05 AM
Bikespace's Avatar
Bikespace
Keep the old spring, but give VanSteel a call. Tell them your application and driving style, and ask what weight low-arch spring they would recommend. Get on their waiting list, and don't expect to see your new spring for months. It will still be worth it, though.
The 385 lb VB&P spring in my 80 is still a bit soft for my taste, but I have no idea what that equates to in the VanSteel line.
To 82 FE7 Leaf Spring
Old Jul 25, 2021 | 08:28 AM
jb78L-82's Avatar
jb78L-82
What rear shocks are using with this composite and what shocks and spring rates in the front coils?^^^^ You need to use a top quality shock with a composite. My VBP 360 with the Bilstein Sports is very firm, handles great, and has an incredibly smooth ride for its stiffness.....
Old Jul 25, 2021 | 03:48 PM
Gale Banks 80''s Avatar
Gale Banks 80'
If You can even find a spring shop these days I would be very careful of telling them what You want. A local Spring shop that is long gone used to do do some work for some of my friends Vettes. They treated every Spring as though it was sagged out and they were there to make it better ! Each and every car I saw after words looked like it had had High Jacker Shocks installed and all You had to do was install longer bolts to get it back to the original ride height if that's what You wanted..
I think a Vendor like Paragon will have all the parts to redo the Spring You have it can't be that hard to do. Despite the age I doubt the squeaking sounds Your getting are from the Spring anyway. If this car still had the original Tires on it a couple of years ago then why would we suspect that the Pads between the Leafs are shot ? I think Your going to go in there and freshen things up and not need to deal with the Spring at all.
I once went to an NCRS meet and there was a very late production 82 with Aluminum Strut Rods on it like a C4 has. Your car does not have them does it ?
Old Jul 25, 2021 | 04:57 PM
augiedoggy's Avatar
augiedoggy
My understanding is it equates to nothing... Because since vansteel purchased the molds for the composite spring from the now defunct VB&P, they have discontinued selling all composite springs but Hypercoils version.. They have even removed the option at this point to place preorders
