Remove and plug off ALL vacuum lines from intake manifold and carb. Start the engine and measure vacuum at idle. This will be the highest level of vacuum you will ever see from the engine. Note: It is possible that vacuum might go a bit higher with different ignition timing adjustment...but not much.
Now re-connect ONE vacuum line and measure vacuum again. If it has not dropped significantly (more than 1-2" Hg), re-connect another line. Continue that process until you see that the vacuum level dropped significantly. If it has, THAT vacuum line and the components on it are suspect for leakage. Chase the culprit[s] down and eliminate them. Then continue with the re-connection process.
When all is completed, your engine should make nearly as much vacuum with everything re-connected as it did with NOTHING connected. THAT is how you eliminate vacuum leaks.
P.S. The carburetor and intake manifold could be sources of vacuum leakage, as well. And you can't "disconnect" them. But, with all vacuum line disconnected and engine idling, you could spray some [volatile] carb or brake cleaner in possible ares of leakage (throttle shafts on carb: anywhere along intake to heat gasket edges on intake manifold, etc) to see if the engine RPM increases (indicating that additional 'fuel' was ingested where it should NOT be able to enter the intake charge).
Now re-connect ONE vacuum line and measure vacuum again. If it has not dropped significantly (more than 1-2" Hg), re-connect another line. Continue that process until you see that the vacuum level dropped significantly. If it has, THAT vacuum line and the components on it are suspect for leakage. Chase the culprit down and eliminate them. Then continue with the re-connection process.
I got a new override switch today. My wiper one had a broken pull down tab and even though I don’t need the wiper one because I have a long hood, I wanted it to look clean. I will take the headlight one and move it to the wiper one as the prop and use the new at the headlight hook up. Still chasing this thing down.
The hose should go from the engine side of the headlight switch to the bottom of the pull down switch.
Yep - The pull down switch is color coded so the white hose and the blue hose are easy to get right on that switch. The headlight switch is not color coded and when you put the hoses on (the wrong way), you get a vacuum leak you can hear and the lights will not open. Switch around those 2 hoses at the headlight switch and all is well. Diagram is crap. Black hose is vacuum source and white hose is the signal to the front of the car.
I got them to go up and down although very slowly by ting the 2 hoses to the actuators and bypassing the tank. I could only get them to work though by connecting my mighty vac to the hose from the relays to the override switch. I’ll spend some more time on it tomorrow. Urgh!.!.!.!.
so try the mighty vac on the hose going from the engine compartment into the pass compartment to hit the headlight or override switch. see if t you can feel vac on hose going to the relays,
good suggestion. I’ll try that later. I’ve done everything to this car myself and have gotten tested many different times and some more than others but this vacuum system is kicking my ***
it’s probably something so fundamental I’ll call myself a dmbass once I find it. If I find it because I’m still tempted for the electric motors.
I think I may have found the culprit. It may be a slight leak in the damn check valve. I didn’t think it was a big enough leak but since my old engine had more vacuum I’m thinking the higher vacuum compensated for a leaky check valve. I ordered it and will have it next week but when I measured the vacuum to the relays it’s only getting like 6 inches. From the manifold I’m getting 12. When I used the mighty vac I can get more vacuum and the relays moved up and down no problem! We will see. Went ahead and ordered a new filter while at it.
Yes. That's why you need to KNOW what maximum level of vacuum the engine will make at idle.
If you do not have a high performance cam in the engine, a normal Chevy V8 will create about 17-20" Hg, if it is not heavily worn internally. Since you are getting 12" Hg with 'things' still connected, you must have a high-performance cam....or you have significant vacuum leaks.
i do have a high performance cam. I’m going to work on this today and tomorrow as the new check valve is due in. Hopefully all goes well and I’m back in business.
Well mission fail here. Back to the drawing board. New valve didn’t do it. Although the old one did have a leak and new one is good. My vac at the source is 15 inches. When I plug in the check valve and measure it at either nipple and plug the other I get like 6 inches. What hell?? Looks like the check valve restricts the vacuum down and not enough to work the system correctly
See if you can freely suck through your check valve with your mouth…..I ordered two brand new ones from two different places and neither were free flowing….both were defective.
I had to put my original one back on…..
When you put the check valve in the line and want to check vacuum level on the output, you connect the gauge to one nipple and you must block off the other one. The check valve cannot 'limit' vacuum level; it can block vacuum or it can pass vacuum. The easy way to test a check valve is to suck on each nipple (yeah, I know....) to see if it passes air. If it's good, it will pass air when you suck on the single nipple side, and it will block airflow when you suck on either of the others.
And, I guess, you still do not know what your engine's baseline vacuum level is at idle. Not sure how you're going to proceed when you have no 'goalpost' to aim at.
Jebby
I’m away from the car for a day or two now but when I took it out of the package tried that it did seem a little restrictive. I’ll double check later but now you got me wondering if it’s chinesium
vacuum was 15 inches with nothing connected. So that’s the baseline. Stays 15-16 until you get to the valve. Then drops (even plugging the other nipple) to like 6
Could be a bad valve. But also look at the condition of the hoses that connect to the valve. There may be a small split at the end of the line...and that can leak more than you can imagine. You can also put a light wipe of RTV on the nipples before you connect the hoses so that a better seal might be achieved.
Is the check valve connected to anything when you test it at the output? If you plug off one output nipple and hook gauge to the other and it checks 6" Hg, there is definitely a problem with the check valve. The only other possibility is that the hose going to the vacuum gauge has a leak!!!
