Help
Old Aug 30, 2021 | 08:25 PM
Kookury's Avatar
Kookury
2nd Gear
Default Help
I have a 1978 corvette. I accidentally crossed the battery terminals and now the car won’t start. It has no crank at all
Old Aug 30, 2021 | 08:33 PM
69L88's Avatar
69L88
What were you attempting to do when you crossed the terminals?
First check the battery to see if it is still good.
Old Aug 30, 2021 | 08:35 PM
Kookury's Avatar
Kookury
2nd Gear
I just got a new battery and I crossed them
Old Aug 30, 2021 | 08:53 PM
righthanddrive's Avatar
righthanddrive
It's kinda hard to reversethe cables on a 78. They are side terminal connections , and they are hard enough to get them on the correct side. Phisher ?
Old Aug 30, 2021 | 09:04 PM
Peterbuilt's Avatar
Peterbuilt
Default Hi and welcome
You most likely burned up 1 or 2 fusible links, which are down buy the starter.
You need a test light or a meter, do you have them?
Here's a schematic:
http://www.keystonestatecorvetteclub...tte%201978.pdf
Post back you progress and someone will help you.
On the schematic the fusible links are 'thermal'
Old Aug 30, 2021 | 09:29 PM
Brian79's Avatar
Brian79
Default Help
Here's a schematic:
As Peterbuilt stated burned up fusible links at starter, do not bi-pass them, get new ones.
Old Sep 2, 2021 | 10:31 PM
7T1vette's Avatar
7T1vette
Batteries are made with + and - on either end. Different vehicles may use the same size battery but require the + on one end or the other. The people who sell these things have no clue what you really need.
With regard to what may have been damaged by reversing polarity to the car... I've never done that, so I don't really know what damage it could do. I'm thinking that the alternator would be the item that would most 'dislike' having the polarity reversed.
To Help
