Input needed on engine diagnosis
This is the original engine in the '76 and I'll summarize what I've done so far and what I found today. It started easily but ran bad and smoked heavily, blue/black smoke at idle and when revving. Plugs were wet and black so I replaced the plugs and wires since they were old and worn as well. It ran a little better but still smoked badly.
Compression is 145 on most, with the lowest at 142 and the highest at 152.
I blocked all vacuum ports including the brake booster and PCV and measured vacuum at idle of around 4-5 inches. It increases a bit when I rev it up.
I blocked the oil breathers and tested the crank case for vacuum, thinking that the intake manifold gasket may be bad. There was an inch or 2 of positive pressure, so that seems OK.
I sprayed starting fluid around the intake and it did not seem to be leaking.
I decided to replace the valve stem seals to reduce the oil burning and also the intake manifold gasket to have a fresh seal.
This is what I found!
The old plugs:
The intake manifold bolts were covered in oil:
Carbon build up around the heat riser was really bad on both sides:
It looks like the original rubber end pieces are there for the intake indicating that this may be the first time it has ever been apart.
When I put the intake on the bench a nasty blend of oil and gas poured out. No wonder it smoked so badly!
It almost seems like the PCV was pulling oil from the valve train into the intake. When I put it back together I will leave the PCV port plugged and let the engine breathe through the valve cover.
Other ideas and observations? Thanks!!
I think I would get a can of Gunk Engine cleaner, pull all the pushrods / lifters and drench the heads letting everything run into the lifter valley and on down into the pan.
Tape off all Intake ports & water ports in the head. Scrub everything and rinse with cheap motor oil.
Reinstall lifters, pushrods, set valvelash.
The china wall gaskets could be from last builder. Some people still use those for unknown reasons.
The oil / gas slurry likely came from that baffle pan under the Intake. There is no way that was introduced into the cylinders.
You have an engine that was not vented properly. I see a faulty PCV Valve. The worst thing to do now is to plug it. Get a new one, and proper hose to the carb. For a PCV Valve to work, the engine MUST have a fresh air inlet somewhere. (other valve cover)
It sure is a mess, but I've already got a good start on cleaning it up. I also thought the slurry was coming from that baffle, but it was pouring out of the intake runners. There would be no way for gas to get into that baffle, and there is a hole in the baffle so it couldn't pool there anyway.
I need to clarify what you are suggesting for the PCV. What I have now is one baffled valve cover connected to the air cleaner and the other side has the PCV valve with a hose to the front of the carb base. I was proposing blocking that port on the carb and leaving the holes in the valve covers wide open to vent, at least to get it running. I'll add a new PCV valve at that point so I can tune with it in place.
I'll drop the pan if I need to but I'll see how well I can clean without that first.
Thanks again!
Blocking the heat riser will lower temps at the manifold base about 100 degrees......to do this, use a Fel-Pro 1204 intake gasket.
You did a good job on the intake....but you need to pull the heat shield off the bottom.....the rivets are push and twist so you can remove them with a good pair of side cutters.....you will **** when you see what is behind that shield.
Use the 1/4" spacer gasket for the carb...you can get it at Cliff's. https://cliffshighperformance.com/pr...sket-250-thick.
You have a LOT of cleaning and scraping to do....and as Heads said above, it would be wise to pull the pan. From there when I do these engine in the car once overs....I replace the pump, pickup, go to a steel collar shaft and a stud to hold it on. Clean the pan all out and use an OS34509T oil pan gasket.
Now is a good time to swap to ARP stainless bolts if you budget supports it.....you will always have them. Intake bolts need a dab of sealer on them or oil will leak past some of them.
When you changed the valve seals...did you use the umbrella style?
Buy a leakdown tester from OTC and confirm the rings are bad.....145psi is ok for a low compression engine but a leakdown is the tell. Make sure your PCV system is in good shape.
Jebby
I recently experienced this in a 1996 rav4 I purchased. Surprisingly seafoam in the oil worked wonders. 2 oz per qt of oil. Run 300 miles. Drain and repeat as necessary. I regained lots of compression and power and reduced oil consumption drastically. Cut open the oil filter and a ton of gunk in the filter.
Once you get it running may want to consider that option.
I agree with REELAV8R about the sludge removal as it is really hurting the engine it appears. I was taught by from a old Cuban mechanic how to remove sludge on Boat motors without removing the engine. We would remove the oil from a warm engine and fill it with the equal amount of Kerosene in place of the oil. Then with NO LOAD on the engine start and let it idle for 10-15 minutes and drain the kerosene mixture. It did an amazing job on removing the sludge and it won't hurt the engine as it is lubricated by the kerosene. Just do not load the engine up with the kerosene in it, idle speed only.
Another time I took a 100k mile old Ford Pickup to a Jiffy Lube and I tried their "Engine Flush" to see what they could do for the poor old 351 V8. They reverse flowed a heated Solvent (smelled something like kerosene) through the engine for about 15 minutes and when they were done the engine was so clean you could eat off the inside of the valve covers. The mechanical parts looked new and worked great for the next few years before I got rid of it. The Rock-wool Filter material was black as coal and really NASTY after the engine was flushed.
Jebbysan is also correct about doing the Leak Down test. The leak down will help you decide whether you need to rebuild now or not. I would certainly perform the leak to learn as much as you can. The leak down test tools are available from many sources and are not expensive. The down side is you need a GOOD supply of pressurized Air to perform the test. The first time I did one it took hours but I have it down to half the time now.
I wish you the very best!
Carefully, carefully pry out the rivets; either reuse them or tap the holes for screws & Red Loctite.
If you completely block Each head's exhaust X-over port; with Both ports blocked, there's little need to reinstall aforementioned heat shield.
You guys were sure right about the underside of the cover haha!!
I kept going back to it throughout the day and finally...
I used WD40 and paper towels. Lots of paper towels!
I bought both the original valve stem e ring seals and the umbrella seals. I can't really see what is under there until I start pulling springs but I suspect there are no umbrella seals.
When you recommended the ARP stainless bolts, did you mean for the intake manifold? I was planning to get a set of those, but depending on the final plan I may end up with Vortec heads so I don't want to commit just yet.
As is a new PCV valve. I checked my old one and the spring works but it doesn't close so you can easily blow or suck air from either side. I wonder how long it has been that way. It's a full on vacuum leak like that.
Thanks again for the help! I'm reading every word and really appreciate it!
Also, roll em on a pane of glass to check if bent. Ball-end must be shiny with no blemish; anything else is garbage.
* inspect all rockers in both their pivot cup And pushrod cup for cracks, microfractures etc; replace any non conforming.
Yeah, I was thinking about where the exhaust goes and if I block the intake ports then it is trapped in the right manifold. I can just imagine the issues. It's hard to fathom the exhaust passing through the intake and that the engine even runs like that. No wonder the heat cooks the oil.
I will try to disassemble the flapper and remove the plate so it still appears to work. I'll need the EFE valve and flapper for the smog check.
Thank you for your help! I have the pushrods soaking and I will give them a careful inspection along with the rockers today. I've got a good magnifier/light to really see the detail. It's crazy how much I reach for the glasses when working on stuff these days. I never used to need those!
I'll report back with more findings and pictures!
