Need Recommendation -- Differential Rebuild(er) in Richmond, VA
Based on the amount of play and your opinions, I guess my side yokes are toast. BTW, does anyone know what would cause a "clunk/thump" from the right side during braking? Is my clutch pack bad? Center pin? :confused:
Anyway, as for the title of this topic... I've read archived posts about rebuilding a differential and I think it's beyond my abilities.
I had tossed around the idea of doing the disassembly/assembly of parts I could do and have the rest (basically, whatever requires a press and puller) done at a shop; but right now, I'm leaning toward either just having someone do the rebuild for me or buying a rebuilt unit.
Can anyone recommend a shop the Richmond, VA area?
Is this something I could/should just take to a Chevy dealership?
I'd welcome stories on what you did to fix your differential/side yoke problem.
Thanks,
Jerry
Thanks,
Jerry
Re: Need Recommendation -- Differential Rebuild(er) in Richmond, VA (jerryp58)
I had my differential rebuilt. I ordered and installed the new yokes myself, before I put the differential back in the car. Try Bair's for the rebuild. Not much to it really... :yesnod:
Platinum Supporting Vendor
Jerry,
What differential do you have in your car(ratio)? We probably have it in stock and you can pick it up tomorrow. If you live in Colonial Hieghts I am sure you have heard of us, Zip Products. We build all of our differentials in house. We will be open tomorrow until 1pm and will re-open on thursday. By the way we are in Mechanicsville, just on the other side of Richmond.
Justin
[Modified by jabbott, 9:42 PM 12/23/2002]
Justin
Re: Need Recommendation -- Differential Rebuild(er) in Richmond, VA (jabbott)
Justin, you saved me a phone call.
I was a little confused by your catalog (I've been to your store many times BTW).
I think I have a 3.08 and I don't see that listed in the catalog.
Also, if I read the catalog correctly, I can drop my differential off and you will rebuild it, CORRECT?
If so, how long does the rebuild usually take?
Thanks,
Jerry
Thanks,
Jerry
Sure I would rather you drop your differential off. It depends on when you drop it off as too how long it takes. We rebuild them tues-thurs so if you bring it to me on a tuesday I should ave it back to you by wed or thurs of the same week. It all will depend on how busy we are at the moment.
Justin
Justin
