Engine replacement 1977
Old Jun 17, 2022 | 12:32 AM
Corvettekid59's Avatar
Corvettekid59
Cruising
Default Engine replacement 1977
Needs some advice..This fall I'm going to pull the stock L48 and replace it with a little more beefy crate engine.
Question is. what type? I'm just looking for something basic with a little lope. Not much but something the trans(350 turbo) and rear end can handle, It's going to be a basic cruiser to shows and what not. I'm looking for complete set up with carb, dist, water pump etc..etc... Something I can just basically bolt in and go.
Here's the hard part. I don't have unlimited funds to spend and I'm not sending my original back as a core. Hopefully somethings out there for under say 5 Grand tops.
Any suggestions?
Thanks!
Old Jun 17, 2022 | 04:45 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
I really don't know if anything has the Corvette waterpump so all your accessories will line up.
I rebuilt my original engine myself with new heads for a little over 3 grand.
Of course I rebuild Harley engines for a living so I have all the tools.
Fair few crate engines out there in your price range. But you may need to swap out the waterpump. (minor).
Old Jun 17, 2022 | 07:46 AM
Heus's Avatar
Heus
About 6 years ago I dropped an ATK HP32 357 crate engine into my 78. It is a 350hp/400 torque crate engine. Roller cam. I see it is currently out of stock at Summit but is well under your $5000 limit.
Old Jun 17, 2022 | 07:52 AM
derekderek's Avatar
derekderek
5k budget? still have orig exhaust? do you live in one of the very few states that emissions inspect 77 cars? PA and CA ore 2. because long tube headers and dual exhaust, pref 2.5 inch the full length and time it correctly will get you more oomph than a 5k engine hooked to that original exhaust system. the 300 hp 69 base 350 is essentially the same engine as the 165 hp 75 L48. most of the diff is timing and jetting for emissions, the way they rated HP and that horrible exhaust system. if your current engine is not a smoking tired dog, heads-cam-intake-carb refresh and proper dual exhaust will get you close to 1 hp per cubic inch.
Old Jun 17, 2022 | 08:33 AM
Bikespace's Avatar
Bikespace
​​​​​What @derekderek said.
Invest that $5K in a manual swap, and start driving a sports car.
Old Jun 17, 2022 | 07:56 PM
Corvettekid59
Cruising
Yes its original exhaust with cats. Delaware does emission inspection but only when you buy it. Then never again until you sell it and new owner wants to tag it in Delaware. Motor has 92K and runs good. just fouls #1 plug from time to time. Not sure if valve seal or rings. Does not smoke at all.
Old Jun 20, 2022 | 10:41 AM
Stormin_Normin's Avatar
Stormin_Normin
Blueprint sells a 390HP 350 for around 4k that should fit your needs. With emissions your options are a bit limited.
Old Jun 20, 2022 | 11:47 AM
HeadsU.P.'s Avatar
HeadsU.P.
Check out on YouTube:
Blueprint Engine factory tour.
Amazing stuff.
Old Jun 20, 2022 | 02:33 PM
augiedoggy's Avatar
augiedoggy
id replace your heads and exhaust... maybe one of those top end kits you bolt on. Gives you more money to possibly change your rear end gears which will make the car feel like you bolted on 100hp alone. save the stock exhaust to bolt on if you sell it.
Old Jun 20, 2022 | 09:11 PM
Corvettekid59
Cruising
I'd do that if i was 100% sure the rings are good. With 92K i rather just rebuild or replace..In this case I rather replace and save the original and let next guy rebuild.
Old Jun 20, 2022 | 09:12 PM
Corvettekid59
Cruising
Leaning that way. For the money they look like the best deal.
Old Jun 21, 2022 | 08:08 AM
augiedoggy's Avatar
augiedoggy
when I do replace my 355 I may go with a 400 from here myself. https://www.mabbco.com/catalog/auto/...urer/chevrolet
Old Jan 26, 2023 | 08:25 AM
Jason9999's Avatar
Jason9999
Deleted
Old Feb 20, 2023 | 07:36 PM
Miniwak's Avatar
Miniwak
1st Gear
I'm looking for a new engine for my 1977 C3, how easy did that engine go in, and how is the performance on it? Any issues or warnings i may need to know about it?
To Engine replacement 1977
