1980 Clock
Old Sep 5, 2022 | 10:53 AM
JiminSTLouis's Avatar
JiminSTLouis
Default 1980 Clock
Hi
My clock’s second hand moves but the minute and hour hands don’t. Can this be repaired or is a replacement in my future?
Old Sep 5, 2022 | 10:57 AM
derekderek's Avatar
derekderek
Pm interpon. He has had success with his clock. About the only working c3 clock…
Old Sep 5, 2022 | 11:10 AM
kodpkd's Avatar
kodpkd
You can remove the clock, Get some alcohol or brake clean start cleaning the contacts and gears. clean the winding mechanism. Use clock oil to lube it,,,, just a tiny bit. They are normally just dirty.
Old Sep 5, 2022 | 03:38 PM
interpon's Avatar
interpon
No expert but..
still working
https://www.corvetteforum.com/forums...ck-repair.html
Old Sep 5, 2022 | 03:48 PM
Brian79's Avatar
Brian79
Default 1980 Clock
Take the clock out and send it to " The Clock Works" for repair.
I had mine out a couple of times, got it to work on the bench, but not so once reinstalled, finally sent it out, still working great a year later.
I did mine in the fall once the car was away for the winter, so I only had to take the dash apart once.
Clock Works is an excellent vendor, with fair prices,
web site: www.clockwks.com
phone: 715-4795759
Brian79
Old Sep 5, 2022 | 04:15 PM
JiminSTLouis
phone: 715-4795759
Brian79
Thanks! I have other “winter projects” that I can do at the same time as the clock.
To 1980 Clock
