Side pipe insert identification help please
Old Nov 26, 2022 | 01:46 PM
wwiiavfan's Avatar
wwiiavfan
Default Side pipe insert identification help please
I pulled these out of the 4” side pipes that are on my car. Anyone recognize the type of insert?
not sure if there is fiberglass between the inner and outer tubes or not.
Was thinking of replacing them with sweet thunder inserts or something for a little more sound. They aren’t bad, but they are a little mellow under 3k.
Old Nov 26, 2022 | 02:26 PM
Crimson Thunder's Avatar
Crimson Thunder
They look very restrictive. The pipe down the middle looks less than 2 inches. I love my STS Spiral baffles.
Old Nov 26, 2022 | 02:38 PM
MelWff's Avatar
MelWff
Multiple manufacturers make that style of insert, Hooker, Dougs, etc. Originally would have packing in the shell. Sound is very subjective. I've had Hooker, Dougs, Spiral Turbo and Sweet Thunder. Currently using Classic Chambered Exhaust.
Old Nov 26, 2022 | 04:45 PM
wwiiavfan's Avatar
wwiiavfan
ID of center pipe is 1 5/8".
Old Nov 26, 2022 | 05:47 PM
MelWff's Avatar
MelWff
Most are 2" and above
Old Nov 26, 2022 | 09:43 PM
Chambered's Avatar
Chambered
Just SLIGHTLY restrictive!
Old Jan 22, 2023 | 12:29 PM
wwiiavfan's Avatar
wwiiavfan
Would Vettepack inserts give a little power bump with a deep tone and not crazy loud?
Engine is a GM performance crate 290hp/350 with a stock quadrajet.
Old Jan 22, 2023 | 12:51 PM
MelWff's Avatar
MelWff
Again sound is subjective, anything larger than the 1 5/8" you currently have will be an improvement. I think the vette pack you are are referring to is 2 1/2" but you didn't provide a link.
Old Jan 22, 2023 | 11:19 PM
Jd21476's Avatar
Jd21476
Ive had the sweet thunders and the STS baffles and I prefer the STS. The sweet thunders were nice but too loud and obnoxious. I could not have a conversation in the car and I had to wear ear protection in the garage when working on the car. The STS has the same sound but just dialed down a bit.
Old Jan 23, 2023 | 01:14 PM
wwiiavfan's Avatar
wwiiavfan
Do you recall what size flowpath your sweet thunder inserts had?
They have 2", 2.25", 2.5", and 3" available.
Old Jan 23, 2023 | 11:59 PM
Chambered's Avatar
Chambered
Pound a potato into each of the sidepipes. Those inserts are restrictive as hell. The exhaust hits a big wall at the entry.
Old Jan 24, 2023 | 12:02 AM
Chambered's Avatar
Chambered
Would Vettepack inserts give a little power bump with a deep tone and not crazy loud? DEFINITELY. There are people on here running the VettePacks.
Old Jan 24, 2023 | 12:42 PM
jim-81's Avatar
jim-81
I love my Chambered VettePacks:
To Side pipe insert identification help please
