why, Bubba, why?
Old Nov 30, 2022 | 12:09 PM
jimh_1962's Avatar
jimh_1962
2018 C1 of Year Finalist
Default why, Bubba, why?
Why would someone bypass a perfectly fine heater only to make it harder for the next guy to hook up the heater hose outlet?
Popular Reply
Nov 30, 2022, 04:50 PM
lars's Avatar
lars
Stop wasting your time. Pony up the $50 and replace the pump.
Lars
Old Nov 30, 2022 | 12:13 PM
lars's Avatar
lars
It's usually done to bypass a leaking heater core because they don't want to go through the effort of replacing it. It's also often done in warmer climates when people don't want the hot water circulating through the heater core and adding heat to the interior of the car. A pretty common Bubba-mod.
Old Nov 30, 2022 | 12:21 PM
jimh_1962's Avatar
jimh_1962
Thats the thing is I get that in our climate the water circulating through heater core can get the cabin hot. Also, the heater core does not leak (leak test with 15 LBs of pressure). I understand why doing it but look at what they put into the water pump. How in the heck am I to take out the fitting from the water pump? The thing is completely rounded off.
It would have been easier to install valves to shut it off.
Old Nov 30, 2022 | 12:23 PM
Shovels and Vettes's Avatar
Shovels and Vettes
Channel locks
Old Nov 30, 2022 | 12:24 PM
walleyfisher's Avatar
walleyfisher
small pipe wrench
Old Nov 30, 2022 | 12:25 PM
jimh_1962's Avatar
jimh_1962
Originally Posted by CorvettePassion
Channel locks
Already tried that even a pair of vice grips.
Old Nov 30, 2022 | 12:31 PM
derekderek's Avatar
derekderek
grab the small square. it may spin out the bigger bushing. looks like they ground it round so it would screw on. may be an excuse to clean up and repaint the front of the engine. in fact, pull the timing cover and oil pan. a LOT of these cars got so few miles they still have the 45 year old nyllon timing gears in them. and they all need the gluck gotten outta the pan. pieces of teeth if replaced or not. pieces of valve seals. and they can stop an oil pump and shear the roll pin and leave you on the side of the road.
Old Nov 30, 2022 | 12:42 PM
domenic tallarita's Avatar
domenic tallarita
Start with removing the square plug that just might turn the other rounded fitting, if not when plug is removed then use a easy out.
Dom
Old Nov 30, 2022 | 02:17 PM
ralphspears's Avatar
ralphspears
Banned Scam/Spammer
Pour some of this on it to loosen it up
Old Nov 30, 2022 | 02:26 PM
carriljc's Avatar
carriljc
If the channel locks or pipe wrenches do not work then consider welding the square headed plug on and use that to back it off.....
Old Nov 30, 2022 | 04:50 PM
lars's Avatar
lars
Lars
Old Nov 30, 2022 | 05:39 PM
jimh_1962's Avatar
jimh_1962
Lars
Yeah, thought about that too.
Old Nov 30, 2022 | 06:35 PM
Capt. Shark's Avatar
Capt. Shark
St. Jude 15 Year Donor
From: Into the Mystic And yet, despite the look on my face, you're still talking TN
St. Jude Donor '09 thru '25
Lars
this
Old Dec 1, 2022 | 08:30 AM
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
Lars
LMAO...Lar's for the WIN! Simple and an anti-Bubba solution.
Old Dec 1, 2022 | 11:53 AM
jimh_1962's Avatar
jimh_1962
I know I can replace the water pump. This pump was already replaced. as far as the timing cover and the rest. It was already done. I could tell it has a new pan gasket and was told it has a new rear main seal. Nothing is leaking so I would rather deal with just trying to get the fitting out first before I go and replace the water pump.
Its heck of a lot easier to replace the pump on a C3 than it is on a straight axle.
Old Dec 1, 2022 | 12:24 PM
ctmccloskey's Avatar
ctmccloskey
Heat it up with a Torch or even a Hot air Gun and then apply KROILS Oil on it and let it soak in. Heat is what helps draw the oil in between the metal surfaces and the oil will then break it loose.
Vice-Grips are the go to for rounded nuts in my garage, I probably have 15 pair from small to ridiculous.
Old Dec 1, 2022 | 12:48 PM
Danish Shark's Avatar
Danish Shark
Are you the Vice Grip Garage guy?
https://www.youtube.com/c/vicegripgarage
To why, Bubba, why?
Old Dec 2, 2022 | 08:42 AM
GUSTO14's Avatar
GUSTO14
Jim, I'm with those suggesting a new water pump. It's a great opportunity to lose a little weight (we can all stand to lose a little weight?). Get an aluminum water pump and you're off to the races! Any excuse is a good excuse...
Aluminum water pumps are quite inexpensive these days - although I like the Stewart's personally... there are others much less expensive.
https://www.summitracing.com/parts/emp-22103
If you do decide to change the water pump, be sure to get the one with the correct 'pilot' - it will save you a lot of grief...
Good luck... GUSTO
Old Dec 2, 2022 | 08:48 AM
rpiechowski's Avatar
rpiechowski
So here is the answer you have been waiting for..... Remove the square pipe plug... Get a set of internal pipe wrenches from Home depot. Use appropriate size and back it out... Under $20..
Old Dec 2, 2022 | 09:51 AM
PJO's Avatar
PJO
Veteran: Marine Corps
Buy an 8 point socket the correct size or a complete set for the occasional 4 sided plug. As I have 2 sets 3/8 drive and 1/2 inch.
