TKX 5 speed Feedback
Old Jul 16, 2023 | 07:44 PM
lionelhutz's Avatar
lionelhutz
Originally Posted by Bikespace
I don't see an issue with downshifting to pass. Drop a gear and disappear? That's the whole point of a manual..
i don't get it either. I just downshift to accelerate. Using the theory that an engine has to readily accelerate or else its being lugged would negate ever using 6th gear in a T56....
I have the wide ratio TKX that I'm putting in a 69 GMC 910. I'm not worried about driving with the 0.72 5th at all but I think/hope the lower ratio gear will help when I'm towing with it.
Old Jul 19, 2023 | 04:18 PM
Lamouree351's Avatar
Lamouree351
I converted my 74 from a TH400 to the TKX close ratio a little over a year ago. I love it, its the single best upgrade I have done to the car. The whole process took me about 40 hours of wrench time working by myself nights and weekends with the car on jackstands.
Im running a 3.55 rearend
Old Jul 20, 2023 | 11:04 AM
Eric P's Avatar
Eric P
Bikespace that B&W 4 speed hangs in there pretty good with the 3.07 gears
Old Jul 20, 2023 | 11:19 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
My buddy George and I drive different roads. We both have Big Blocks.
He wants to use 5th gear at 50-55 on 2 lane roads, @ 1900rpm.. So he has 411 gears. He had 373s and did not like them for those roads.
I want mine to act like a 4spd and then use the OD gear on the interstate. Around here that is 75mph + or you get run over. I won't use 5th until 65mph @ 1900.. I have 323s.
If you have a SB with a big high rpm cam you might want to keep it at 2500+ even in cruise.
So there is no one correct answer.
File Type: xls
Old Jul 22, 2023 | 08:57 AM
wwiiavfan's Avatar
wwiiavfan
I bet that big block with 4:11’s is pretty spicy off the line!
Old Jul 22, 2023 | 09:21 AM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
Yeah it's almost 12:1 off the line.
Enough that he twisted the half-shafts at ATCO!
