More carb horse
Old May 22, 2024 | 02:10 PM
Shawkrider's Avatar
Shawkrider
4th Gear
Default More carb horse
I'm new here, I have a 68 327 with a quadrajet.
I'm looking to get more power so I'm thinking a better carb is a good start. I've seen the Holley Snipers and Demon carbs but wonders what's the highest recommended setup first time, so I don't have to keep guessing and trying new stuff.
Would I need the choke or divorce choke, not sure which way to go on that and why?
Thanks for any advice.
Old May 22, 2024 | 02:37 PM
interpon's Avatar
interpon
not sure if that is the low hanging fruit is carb.. maybe focus on ignition timing and exhaust first.
maybe consider below as well
https://www.corvetteforum.com/forums...d-to-lars.html
Old May 22, 2024 | 03:19 PM
Hopper12's Avatar
Hopper12
^^^^ Interpon is spot on. "The grass isn't always greener on the other side of the carb fence".
Old May 22, 2024 | 03:42 PM
Piersonpie's Avatar
Piersonpie
I agree with the posts above. If your engine is stock or even modified a well set up Quadrajet should have more than enough CFM capability to supply a 327.
Have any other modifications been made to the engine?
Old May 22, 2024 | 03:56 PM
Tampa Jerry's Avatar
Tampa Jerry
What engine is in the car? Is it the original engine? Could be a 327/300 or a 327/350 or something else. Jerry
Old May 22, 2024 | 04:58 PM
7T1vette's Avatar
7T1vette
Your Q-Jet carb is not the 'power' restriction for your engine. It can flow 750cfm which is MUCH more that your stock engine can use. Put your money where it will do some good. Heads/cam/exhaust is where the power is made (if you don't want a full engine rebuild).
P.S. You should make sure that the carb secondaries are fully opening when the accelerator pedal is pushed to the floor. Also verify that the secondary lockout lever on the Q-Jet is releasing properly when choke is warmed up. Next improvement is to re-curve your distributor for maximum performance. Do these things first...BEFORE you start throwing money at more HP.
Old May 22, 2024 | 05:15 PM
augiedoggy's Avatar
augiedoggy
I thought the qjet was actually 780cfm... Its like one of the few things that Dont need to be changed here honestly.
Old May 22, 2024 | 05:52 PM
Piersonpie's Avatar
Piersonpie
A 68’ 327 should have one that’s rated at 750 CFM.
There’s also late 70’s Chevy and early 70’s Pontiac carbs that are rated for 800 CFM…
But those ones tend to test on a flow bench closer to 890 CFM.
Plus there’s those “new” ones that are only rated at 600 CFM.
Also there’s those Edelbrock ones that are rated at 850 CFM.
It’s all so confusing
Old May 22, 2024 | 06:15 PM
Richard Daugird's Avatar
Richard Daugird
Weren't Caddy QJets 850 CFM?
Old May 22, 2024 | 09:36 PM
Shawkrider's Avatar
Shawkrider
4th Gear
To answer all of your question in one place.
It's a stock 327 1968 Corvette with stock quadrajet.
No modifications to the engine that I know of.
The reason I was looking to replace the carb is because it needs a complete rebuild. In efforts to keep it matching numbers, I guess I'll just have it rebuilt.
I believe the exhaust are straight. No cats, no muffler, 2¹/² round. Would love some hookers with sidepipes but don't like toasted calves.
Old May 22, 2024 | 09:53 PM
Bikespace's Avatar
Bikespace
If you have it rebuilt, have it rebuilt by @lars
Otherwise, buy Cliff Ruggles' book and rebuild kit and DIY
https://cliffshighperformance.com/pr...category/books
Old May 22, 2024 | 10:08 PM
Newbomb2469's Avatar
Newbomb2469
The OEM side pipes have a heat shield that will protect from burns
Old May 23, 2024 | 08:39 AM
7t9l82's Avatar
7t9l82
Never been burned by my side pipes because I wear long pants. Always wear long pants riding motorcycles too.
Old May 23, 2024 | 08:44 AM
HeadsU.P.'s Avatar
HeadsU.P.
Shawkrider,
Its a little more to it than waiting for UPS to bring you a new Holley. (if you go that route)
Right out of the box, the Holley will run very well. Unfortunately, not on your stock Intake.
You have the spread-bore bolt pattern.
Holley is square-bore.
So, that is why the Edelbrock 2101 Performer is so popular with our Vettes. It's a spread-bore and a square-bore pattern.
But wait! There's more. It fits under the hood too.
Old May 23, 2024 | 09:10 AM
augiedoggy's Avatar
augiedoggy
So do many folks running the hooker style myself included.
To More carb horse
