Hot air cleaner
Old Jun 17, 2024 | 03:13 PM
78whtshark's Avatar
78whtshark
Default Hot air cleaner
Drove my 1970 350 roadster the other day, it was 90 degrees outside, water temperature was about 195 degrees, drove about 25 miles then remembered to check fuel line at carburetor (it was leaking and I had retighten) no leaks, BUT the air cleaner was too.hot to touch. Why, ? I literally had to use A rag to remove air cleaner...
Old Jun 17, 2024 | 04:30 PM
lars's Avatar
lars
The air cleaner is going to be the same temperature as the rest of the engine: If your engine is at 195, you have 195-degree air blasting back from the fan and hitting the air cleaner. Try removing a 195-degree pan out of the oven... Nothing abnormal about the air cleaner being too hot to touch on a hot engine.
Old Jun 17, 2024 | 06:30 PM
78whtshark's Avatar
78whtshark
Thanks, I usually don't pull the air cleaner off when car is hot...Thus I am glad it normal to be hot like motor...
Old Jun 18, 2024 | 05:37 AM
theandies's Avatar
theandies
This is the truth. I've had to use gloves or an old rag to take mine off after driving.
Old Jun 18, 2024 | 08:08 AM
7t9l82's Avatar
7t9l82
You can wrap some pot roast and veggies wrapped in aluminum foil put it on your intake and go for a long drive and have a tasty dinner ready. Plus the car will smell wonderful 😊
Seriously, it's an oven.
Old Jun 18, 2024 | 11:26 AM
MelWff's Avatar
MelWff
Have you considered switching to a 180 thermostat?
Old Jun 19, 2024 | 02:03 PM
7T1vette's Avatar
7T1vette
Switching the thermostat won't reduce the running temperature of the engine. It will only set the LOWEST POSSIBLE operating temperature of the engine. Once the thermostat is fully open, the rest of the cooling system sets the operating temperature.
The thermostat is there to help get the engine up to decent operating temps quickly and also to assure good engine temps in cold weather.
Old Jun 19, 2024 | 02:05 PM
MelWff's Avatar
MelWff
Exactly, there is no reason to believe the lowest temperature will Not be reduced by going to a 180 since it was common prior to emissions.
Old Jun 19, 2024 | 03:23 PM
7t9l82's Avatar
7t9l82
If the thermostat opens at a cooler temperature and the system is capable of it the engines coolant will run cooler. Pre emissions engines ran cooler, who decided hotter temperatures were beneficial,?
Old Jun 19, 2024 | 05:18 PM
gbvette62's Avatar
gbvette62
The engineers at the automakers who had to come up with ways to meet Federal emissions regulations and design effective emissions systems. The hotter running temps help burn off engine emissions.
Old Jun 19, 2024 | 05:25 PM
7t9l82's Avatar
7t9l82
I knew that part but there are people that insist cars need to run hotter regardless of emissions .
Old Jun 19, 2024 | 06:38 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
they are fools. No engine runs better hotter, thermodynamics wont allow it
To Hot air cleaner
