Ready for Carb Upgrade
Just don’t expect to send a “mix matched “ Q core to a rebuilder, they must have the correct parts and it must be the right carb for your application. Mine has a one year only(1971) high idle solenoid. Please don’t try to cut corners on the rebuilder or pick up a newer “rebuilt” carb from a box store.
Good luck! KC
If you don't have a workable quadrajet check out the Holley.
This is almost half price. Couldnt even tell mine was used. Came in original packaging with all new accessories
https://www.holley.com/products/fuel...ts/FRHR-680-VS
Sometimes looks can be deceiving, but from the pics it seems to be in decent shape and may be able to be tuned as is. Again a CSM for your car would help rule out if you really need a different one.
Also because the Quadrajet was used on all Gm products(along with others like Ford/Dodge)look around and see if you can find someone there that may have another brand of GM that can help you gain more knowlege and help with maybe a rebuild. Heck, even someone that works on European stuff could be of some help when it comes to the actual mechanical part of it.
If you can find someone to give you a hand make sure to come back here with any questions. Lots of knowlege here and usually someone can figure it out.
The Holley is the second best out there, but they are readily available, can be respectably tuned by almost everybody. Parts are readily available almost everywhere. Tuning for HP and getting rid of bogs is easy on a Holley. Easy is a good word for a Holley. But you must have the correct model to start with, and tuning the idle-cruise "driveability" circuits can be very difficult. They will make the same power as a Q-Jet but are much easier to tune to get it there, so some claim they make more power. But they are difficult to get the same gas mileage or driveability as a Q-Jet. There are a dozen or so variations. And you can tune a Holley for almost any kind of low vacuum race cam. Holleys can be easily re-tuned for most engine upgrades.
The Edelbrock AVS is like the third choice. One size does not fit all, they only have a couple of versions. So it rarely works well out of the box. Tuning kits are more available than Q-Jet but less available than Holley. They are actually easier to tune on top of the engine than either of the two above. But even in the long run they never seem to dial in as well as the other two. With some work, they can be tuned to drive as good as a Q-Jet, and give good mileage, but a Holley usually out powers it. They just don't seem to have a major strength unlike the other two.
In a word:
QJet = great driveability
Holley = easy HP
AVS = ??? cheaper maybe??
With any kind of carb tuning these days you should consider an AFR meter.
The Edelbrock is a universal carburetor as is a Holley and may need a tuning kit and some tuning along with a 2101 intake or the new EPS intake but they will work great , you will need Edelbrocks heat insulator gasket and a kit like this to get you started with the low fuel line hook up and maybe upgrade your valve covers at the same time for the breather tube
https://www.jegs.com/i/Edelbrock/350/1407K2/10002/-1
now if you went with a AVS2 they have annular boosters and are as close to Fuel Injection as you can get with a carburetor, here’s a link for the 650 version
https://www.jegs.com/i/Edelbrock/350/1905K1/10002/-1
I’m actually testing some Edelbrocks against my Quadrajet on my 1980 L82 right now just for conversations like this and I’m currently on a 1406 economy electric choke 600 and with the choke setup it starts cold and runs equal enough that I don’t think anyone could tell by driving it that it’s not the QJet and this economy 600 version is only 1 mph slower than the Quadrajet in the 1/8th mile almost 2 in the 1/4 out of the box setup no tuning so I might be able to match the Quadrajet mph with a little bit of tuning , I’m happily surprised how close it is.
I have a 1405 eBay core,1406 Craigslist 60.00 special (being tested right now),1407 eBay the seller stated bought new and ran bad and took it off (disgruntled Edelbrock employee as it totally had the wrong parts inside, lol
) , EPS800 eBay core missing choke and a AVS2 650 new from Jegs to play with just for fun and frolic .
A second one if you prefer.
They are almost impossible to beat as far as throttle response, driveability, reliability and gas mileage vs the other types mentioned.
Especially if your engine is anywhere close to stock.
A Q-Jet can be difficult to mod however, so if you have engine mods, depending on what they are, it may be easier to switch to an Eddy or a Holley. They are easier to self-tune.
If you do not have the GM Historical archive information for your car, you need it.
I attached a 1974 here.
Deep in there it has your carb #.
It says your stock Q-Jet is a 7044502. L48, auto. It is a different # if you have a 4spd. You should check the number on your drivers rear screw to be sure the one you have now is correct anyway.
I am not sure why you think you need to change it, but it may just need tuning or refreshing,
You will not gain HP by changing the carb, unless you current one is not working "right".
They are not that hard to find. You could buy one off e-bay and rebuild it yourself. It's a good learning experience.
You can find good parts here:
https://www.carburetion.com/CarbNumb...Number=7044502
If you prefer to buy a used Q-Jet they are out there:
Here's an e-bay one for $70 but you never know what you get used.
https://shorturl.at/epK7w
If you prefer to buy a complete Q-Jet , that is quite likely to be done right, try these guys:
https://quadrajetpower.com/chevrolet-1974-350-7044502/
$549 rebuilt correctly, To me that is a better buy than an $800 Holley.
If you have a few engine mods, they can tweak it for you.
A Q-Jet can work well to 400HP and a little beyond, if you work it correctly.
I'll also attach the GM Q-Jet service manual.
You'll need that too.
Good luck.
