Drivers Side Dash Panel
Old Apr 20, 2025 | 12:18 PM
Cobfree's Avatar
Cobfree
Default Drivers Side Dash Panel
Does anyone have a video or help with the removal of the drivers side dash panel on a 68. I need to get in and replace the brake light switch.
Old Apr 20, 2025 | 12:41 PM
forman's Avatar
forman
Usually the switch is on top of the pedal area and the dash doesn’t have to come out it’s kinda tough getting under there I had a hard time navigating the area myself I ended up taking the seat out to get up there
Old Apr 20, 2025 | 04:40 PM
Eliredandblack's Avatar
Eliredandblack
Some guys have used a stool placed outside of the door (on the ground) that supports their back. I agree that removing the seat is necessary, unless you know someone who works in a circus as a contortionist!
Old Apr 20, 2025 | 05:41 PM
robertea's Avatar
robertea
Here is basically how you change a brake light switch. Always a lot of fun!
Old Apr 20, 2025 | 05:54 PM
forman's Avatar
forman
That’s it … 😂and it works
Old Apr 20, 2025 | 06:21 PM
BLUE1972's Avatar
BLUE1972
put a few milk crates right outside the door with a moving blanket on top. makes it easy to get under the dash
Old Apr 21, 2025 | 08:45 AM
Cobfree's Avatar
Cobfree
Thank you all for the comments. I did it once and it was not easy.
Old Apr 21, 2025 | 09:59 AM
7T1vette's Avatar
7T1vette
4 bolts will remove the driver's seat and make life MUCH easier when working under the driver's dash area.
To Drivers Side Dash Panel
