What noisr is this?
Old May 6, 2025 | 05:16 PM
DHer67's Avatar
DHer67
Default What noisr is this?
Rattling from bell housing area. Just rebuilt the Muncie and installed it. It was making this noise before I rebuilt it and I thought it was the transmission. Now it's getting worse.
Old May 6, 2025 | 06:13 PM
lars's Avatar
lars
Noise from the bellhousing area has nothing to do with the transmission. That's a clutch/pressure plate/throwout bearing/pilot bearing/clutch fork problem. Disassemble it and inspect it. Replace the bad parts.
Old May 6, 2025 | 07:45 PM
HeadsU.P.'s Avatar
HeadsU.P.
DHer,
The above is usually 95% of the issues you describe.
Here are 5% more.
Both motor mounts appear ok?
Trans mount ok?
Cracks or missing bolts in bellhousing?
These ^^^^^ are all "alignment" checks.
Spring missing on clutch fork?
Dust / stone shield rattle?
Z-bar pivot ball in the block tight & ok?
Old May 6, 2025 | 07:48 PM
carriljc's Avatar
carriljc
Try removing the flywheel cover and see if it changes. Does the noise change as it warms up?
Old May 7, 2025 | 08:30 AM
7t9l82's Avatar
7t9l82
Why would someone rebuild a transmission and not check the clutch assembly and related parts?
Old May 7, 2025 | 11:27 AM
7T1vette's Avatar
7T1vette
Hmmm.... 1.) Doesn't know better; 2.) It worked before; 3.) Needed to save money.
When you change that bearing, make sure that there is some "free play" in the clutch pedal. Having constant pressure on that bearing [even if its light pressure] is a major cause of early failure.
To What noisr is this?
