Quick timing question
Old Jun 6, 2025 | 03:22 PM
kansas123's Avatar
kansas123
Default Quick timing question
Most of what I have always read says the (factory) 8° is ridiculous, go with 12°. I think for more power, run better, might be less efficient. So I'm set on that for my L48 '72. (And gives me 30° with vacuum and 700 rpm idle). Won't do any harm? Thanks
Old Jun 6, 2025 | 04:35 PM
lars's Avatar
lars
You need to check and set your total timing and make sure the total is at 36. Once done, see what your initial ends up being - it should fall somewhere in the 10-16 range. Setting the initial without knowing the resulting total timing is what can do harm...
Old Jun 6, 2025 | 04:48 PM
kansas123's Avatar
kansas123
Thank, total is 30, so i can go more looks like...
Old Jun 6, 2025 | 09:00 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
I'd say doing this sort of all-in timing results in a more efficient engine than the retarded timing on the label. You get better combustion at a more optimum place in the cycle and rpm range.
Old Jun 6, 2025 | 09:38 PM
kansas123's Avatar
kansas123
I shall make the change tomorrow. Thanks for the info guys
Old Jun 7, 2025 | 07:25 AM
ScottinMaine's Avatar
ScottinMaine
David - I think you mis-understood Lars' comment, total timing is not initial plus vacuum at idle, it's initial plus mechanical at full advance at some rpm that brings in the full travel of the weights. Search for his papers on getting the distributor and the timing correct, it'll make a world of difference.
Old Jun 7, 2025 | 10:50 AM
kansas123's Avatar
kansas123
Old Jun 7, 2025 | 11:03 AM
lars's Avatar
lars
That's absolutely correct. Total timing has nothing to do with vacuum advance, and does not include the additional advance from the vacuum advance control unit - total timing is checked and set with the vacuum advance unplugged. Total timing is initial timing plus the full centrifugal advance - pegged out - at elevated rpm. Read my papers and set your timing up correctly. If you do not have my papers, e-mail me for a correct and current copy - I don't post my papers, and those posted by others are usually either obsolete or fake.
Lars
Old Jun 7, 2025 | 12:32 PM
kansas123's Avatar
kansas123
Thanks, I still have your papers.
Old Jun 7, 2025 | 05:00 PM
VERYSOON's Avatar
VERYSOON
Kansas
I copied this out of my records for my 1969 350/300 Corvette. This will give you an idea of where the numbers will end up. The advance limiting plate from Lars smoothed out low rpm acceleration, ie, going from 55 mph on say 60 mph.
VS
February 1- Installed Lars’ Vacuum Advance Corrector Plate with new B26 vacuum canister (Napa VC1765) replacing the B1 can at Lars suggestion. Idea is to limit vacuum advance but let it come in at a lower vacuum level. This is done because initial mechanical advance is set to 12* with a total of 34-* all in at 2900 rpm and you want to avoid having total mechanical plus vacuum at over 52*. I set the timing as above, mechanical plus vacuum is about 46* with the new can adding 12*. Idle at 750 rpm.
Test drive was perfect. Smooth strong power, instant response @ 71,626 miles.
Old Jun 7, 2025 | 05:04 PM
MelWff's Avatar
MelWff
In order to set the total mechanical advance to 36 as recommended above you first have to buy a spring kit such as a Mr. Gasket 928G since the stock advance springs are too stiff.
Old Jun 8, 2025 | 07:44 AM
ScottinMaine
You can also remove the springs altogether to set the max advance, and then try the Mr. Gasket springs until you get the 'max at 3000 rpm' correct.
To Quick timing question
