Stumbling and dies when hot?
Old Jul 16, 2025 | 07:52 PM
lars's Avatar
lars
Originally Posted by greaser2
Update; replaced the coil, D-cap, rotor, and ECM.
A 1978 Vette does not have an ECM.... What year configuration are you running?
Still can't rule out the chock but thinking if I unplug it after it warms up, it should not cause it to die if that's the problem?
1978 Corvette does not have an electric choke that can be "unplugged." Sounds like you have a hacked, incorrect, non-stock configuration that you need to get ironed out. If you "unplug" an electric choke after it warms up, the choke will then close and it will kill the engine from a flood-out condition.
Sounds like you have a hacked mess on your hands...
Old Jul 17, 2025 | 08:58 AM
greaser2's Avatar
greaser2
I said ECM but meaning ignition module. I have 4 cars I'm working on currently so...
I saw the black plastic face on the choke and assumed it was electric, but it's not electric. Car is stock accept for Retrosound radio and aftermarket power antennna.
Old Jul 17, 2025 | 09:24 AM
Piersonpie's Avatar
Piersonpie
Posting some pictures of your engine bay with the air cleaner and ignition shielding off the engine could help people solve your problem.
Old Jul 31, 2025 | 06:13 PM
greaser2's Avatar
greaser2
Update, changed the Fuel pump and drained the tank. Refilled with Non-ethanol that I was lucky to have down the street. Two shorter drives so far that went well until I get home and park/idle. It will occasionally stumble a few seconds but come right back. May go several minutes before it stumbles again but carb seems to adjust and comes right back. I can clearly see the fuel bowl is full and stays full. Squirters work fine.
Thinking I had Vapor lock from poor pump/ethanol gas. Can’t really test without filling with assuming to have ethanol gas.
The remaining stumbling I would think is from inside the carb but only within a small section. Likely a carb design issues, maybe a rebuild would help?
Old Jul 31, 2025 | 07:34 PM
Piersonpie's Avatar
Piersonpie
If you can get it to idle you can check your ignition timing. What is it set to? With and without vacuum advance.
Old Jul 31, 2025 | 07:49 PM
greaser2's Avatar
greaser2
So I checked it without vacuum last weekend, 17 degrees at idle (800rpm) and 37 degrees at 3000 rpm.
Old Aug 1, 2025 | 09:33 AM
signify's Avatar
signify
Check sock in fuel tank it acts as a filter it will shut you down at any time at idle.
Old Aug 10, 2025 | 04:15 PM
greaser2's Avatar
greaser2
Got the Crab rebuild complete, no surprises. Back together set the fuel/air screws at 4.5 turns out and it starts right up on the key. Before taking on a drive wanted to set the fuel/air screws with a vacuum gauge. I’ve connected my gauge at the PCV hose, port just above the F/A screws and to the brake booster connection but adjusting the screws in and out has no effect on the vacuum. I’m pretty steady at 14-15 vacuum from 5.5 out to 1.5 out. No setting adjustments seems to impact the Vacuum or idle. What am I doing wrong.
Old Aug 13, 2025 | 04:23 PM
greaser2's Avatar
greaser2
Got a carb rebuild done and that seems to have fixed the slight periods of idle drop when hot fixed. Haven’t had the car die when hot in a couple of weeks since replacing the fuel pump and refilled with non-Ethanol. Will have to figure out when/if I can go back with regular Unleaded. Hoping it’s just a summer issue.
Old Aug 13, 2025 | 08:21 PM
interpon's Avatar
interpon
Post pics…
measure fuel pressure and flow.
how can you see bowls full?
pics will help all to help you.
good luck!
