71 LT no spark
I had my Dave of T.I.Specialties rebuild my distributor and help me get the parts working together the best way possible. He replaced the amplifier board with a more recently designed unit which is more robust than the original unit was and that is a good thing. My original board was returned with the parts as it was still functional.
If the unit failed and blew a fuse or anything then I would also check the source of power and even the fusible links in the area of the left front fender. Being a Corvette means you always check for a good ground at the component. Bad grounds are just as big a problem on 50+ year old engines.
That said, most of the GM material shows the "R" and "S" terminals at 3 and 9 o'clock
respectively while replacement units will show their positions swapped so be careful if you get a new one.
I confirmed switched 12V at the "S" terminal. (9 O'clock on my solenoid) There is a heat shield protecting the solenoid so getting a lead onto the "R" terminal
was a challenge and could only be "confirmed" by feel not by sight. I read 6-7 V at the coil *[edit, from the solenoid R contact, NOT the coil] from this lead while cranking. It should be more.
Coil pretty much Ohms well .5 primary. though a bit high @13.2K secondary.
As they say, "When you hear hoofbeats think horses not zebras." Pulling the coil lead I found this!
Coil side of lead was burned and disintegrated.
I am not familiar with this types of wires but the lead seems to be graphite impregnated braided line and no metallic material.? On the coil side it was totally frayed
and turned to dust inside the connection. could explain why the car has 6 Accel plug wires and 2 run of the mill plug leads.
I Will dig up a spare coil lead next day or 2 and retry. Stay tuned.
BTW, I would check the terminals for all of the wires since it appears that they were cut and crimped, so they all may be crimped poorly.
For extended testing, the HEI module needs to be attached to an aluminum heat sink, or just a piece of aluminum. (To keep it cool)
This setup does NOT require any starter wiring connection.
On reinstall I severely pinched the TI amp harness between the shroud and a sharp bit and pierced the amp harness.
(Does anyone know how to "easily" remove the LT plastic rad shroud as i likely have to go back in?!)
Fixing the pierced wire and swapping out the shot coil lead and the car fired right up though a little lumpy. Will procure a new reliable wire set and hopefully this particular drama is put to bed.
I found the pinched wire as i was looking for ways to extricate the amp. That looks like one miserable job as there is no way to get hand and wrench in there while seeing
what you're doing and the through bolts to the fender well are as rusted as you might think after 50+ years.
I had already ordered an HEI module to test the rest of the system so I will pre-wire it and have iit ready to splice in if/when the TI amp fails.
Thx all for the help.
