minimum vacuum needed
Old Jul 26, 2025 | 08:23 PM
Kevin LD's Avatar
Kevin LD
Default minimum vacuum needed
Just wondering if we need 18 lbs of vacuum or will 10 do it. The Blueprint 350 341 hp engine has 18 and the 350 390 hp and up only has 10. Will I have to run any kind of vacuum booster if I go with an engine that only has 10?
Old Jul 26, 2025 | 08:41 PM
Piersonpie's Avatar
Piersonpie
Do you have a link to the 390 engine you’re looking at? The one I’m seeing on Blueprints website says 12 inches at idle, which people run with no issues.
Originally Posted by gkull
You do really nice work! But I would tend to say that such high vacuum is not required. I don't think that I have had a motor in my vette for 35 years and 178,000 miles that has produced 12 inches of vacuum even at 1200 rpm idle speeds because of big solid roller cams. I've had the opening headlight not work from lack of vacuum, but never the brakes. Pad compound is a big factor. The super clean wheel ceramic pads that you get cheap at the local parts store might have very low brake TQ. I have tested all kinds of pad compounds out road racing and failed stock brakes even with 600 degree fluid and never with high vacuum engines
Old Jul 26, 2025 | 08:51 PM
C3 Stroker's Avatar
C3 Stroker
With my 383 I had 10" of vacuum and no problems.
Old Jul 26, 2025 | 09:32 PM
Kevin LD's Avatar
Kevin LD
I just looked again and can't find where I saw the data that said 10 inches of vacuum on 390 hp BP engines and up. Looking tonight like I said I can't find that info, in fact they are 12 or 13 inches of vacuum. Has anyone had vacuum issues like headlights or brakes? I wonder because some people are going to the electric headlights, which might be because of loss of vacuum when using the bigger cams and separation of 110 deg or less. I don't want to choose an engine and then have to put a vac booster on or change headlights to electric. I'm asking because I'm sure there are guys out there that know better than I do so educate me please.
Old Jul 26, 2025 | 09:39 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
You'll be fine. Guys change over to electric headlight doors because they don't know where to get quality replacement parts or they just don't understand how the vacuum systems work.
Silly I know.
Old Jul 26, 2025 | 09:40 PM
Stormin_Normin's Avatar
Stormin_Normin
12 is about minimum for decent brakes.
Kevin LD's Avatar
Kevin LD
There is a 383 410 hp with 14.5 vacuum. Which is the closest to the 350 341 hp with 18
Old Jul 26, 2025 | 10:05 PM
Rebelyell's Avatar
Rebelyell
JMO: 195cc intake port volume on a 350ci/341hp motor is probably limiting both intake charge velocity and manifold vacuum; velocity matters.
Old Jul 26, 2025 | 11:15 PM
lars's Avatar
lars
With only 10" of vacuum, you need to be aware of fuel metering signal to the idle and transition circuits of the carb you are using. The idle circuit discharges fuel from an orifice below the throttle plates as a result of manifold vacuum - not as a result of airflow through the venturi and the Bernoulli Effect. If you change the manifold vacuum from 18" to 10", your carb will lean out grossly, and it may not have adequate flow capability through the idle circuit to have adjustability range to maintain idle mixture at the poor manifold vacuum spec. Some carbs are designed to handle this. Others are not. You will also have problems with ignition vacuum advance - you may not be able to meet the "2-inch rule" requirement for vacuum advance, which will have a significant change requirement on your ignition timing specs in order to get the engine to idle acceptably.
Lars
Old Jul 27, 2025 | 12:22 AM
4-vettes's Avatar
4-vettes
Lars makes some good points. For a street driven engine. Regardless of displacement. Cam selection that pulls down vacuum that low isn't really the best choice. I run a fair bit of cam for a street driven car. Idle vacuum is 14 -14.5 inches.
Seriously, a Cam more rowdy than this becomes a real pain in traffic. As well as the issues mentioned above.
Old Jul 27, 2025 | 01:05 AM
lars's Avatar
lars
Exactly. A lot of this is driven by camshaft LSA. Get it too tight in a street engine without enough compression, and drivability and tunability will suffer... Those "Thump-Yo-*****" cams are typical of this...
Old Jul 27, 2025 | 01:49 AM
4-vettes's Avatar
4-vettes
And the young guys just love that crap. And there horrible to drive at low speed on the esplanade (beach front) or parking lots or just slow and heavy traffic. Just terrible.
But they idle with a thump, thump, thump!
Cams for *******.
Old Jul 27, 2025 | 08:26 AM
7t9l82's Avatar
7t9l82
All excellent points. Follow the advice now so you don't have to start another post later on how to fix it.
Old Jul 27, 2025 | 11:26 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
I agree completely with the above posts.
I ran a large 254* solid cam in my LT-1 for 27 years.
(A 240* hydraulic would perform the same.)
It idled at 900 with only 10.7" of vacuum.
If I idled it any lower, the engine made so little power, using the PS would stall the engine, in a parking lot.
It was the DZ302 or 63 Fuelie 30-30 cam with 114 LC.
Honestly it was kind of a pain on the street.
The low end TQ was pretty light, and it did not come on very strong til 2700rpm plus.
Which meant 1500+ to come off a stop light.
I raced it a lot, and it would rev hard to 6700 rpm, so that is why I left it in there.
But I never had trouble with the power brakes.
And I autocrossed it and used the brakes hard.
Past idle it has a lot more vacuum than that, and the brakes work fine.
The booster stores a couple brakes worth of power.
The only time I ever even noticed was putting around in a parking lot, and using the brakes a lot.
It would actually change the way the engine idled.
I even ran the valve lash loose, at .040", which killed some duration, but actually made it faster, and drive better.
For a street cam, you would be well advised to run 230* or less, and have 12-14-15" of vacuum, at idle.
And a "normal" 110-112* LC.
It will run better, everywhere , except maybe 6300 rpm plus.
Oh and changing the idle a 100rpm, can add or subtract an inch or two of vacuum, with a cam like that.
Which may be why you are getting different opinions on that.
The Blueprint 350-390 has a much smaller cam than I had, and much better heads.
So similar HP, just at a little lower rpm. Say 6200 tops.
Yep dyno curve says the party is over by 6 thou.
I'll bet the idle vacuum is 12" -14".
But it only has a a 9.2CR, that is kind of light.
That cam would like 10CR much better, it would run much better.
They are being very conservative.
That thing might even run on regular gas.
In a light car like a C3 10:1 would be much better.
It will make the throttle much more responsive.
Old Jul 28, 2025 | 05:54 PM
Kevin LD's Avatar
Kevin LD
I run an automatic trans so upping the idle is not a good idea for my setup. I'm really looking at the 350 390 hp with 14.5 vac. All the HP I'll need to cruse with and it does have a nice idle non rump cam with 115 deg. I like that combo for me and thanks everyone your input really dialed me into what I need. Oh and yes they say it will run on 87.
Old Jul 28, 2025 | 07:24 PM
4-vettes's Avatar
4-vettes
Yes I think you'll be very happy with that.
Old Jul 28, 2025 | 09:22 PM
drwet's Avatar
drwet
FWIW my 427 small block has about 11 inches of vacuum and I don't have problems with vacuum operated accessories. I would definitely run a little less camshaft if I were running an automatic.
Old Jul 28, 2025 | 10:00 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
Yeah you will be real happy with that one!
It has a cam much like a 350-350HP L46, one of my favorite all around SBCs.
Great power from idle to 6000 rpm redline.
A little less compression to run regular gas.
And much more modern better flowing heads than that old motor to up the HP by 40, with zero driveability drawback.
You could easily drop the idle to 700 ish or so for an auto.
To minimum vacuum needed
