OBD1 Code 42
Old Aug 4, 2025 | 03:28 PM
John@scc's Avatar
John@scc
Default OBD1 Code 42
Hey guys,
I have a Code 42 on my 1982 Corvette, which indicates a faulty EST (Electronic Spark Timing). Another source I found says faulty wiring between Ignition Module and ECM.
Has anyone else experience this issue and what was the fix? I'm wondering if my ignition module might be going bad.
Thanks in advance.
Old Aug 4, 2025 | 08:11 PM
Fly skids up!'s Avatar
Fly skids up!
Did you forget to reconnect the EST plug after checking the timing? That would be the most common answer. However it gets complicated after that. There's are many reasons for code 42, more than a simple form answer. What you need is the factory service manual which has a flow chart that will guide you through the diagnostics.
Old Aug 4, 2025 | 08:57 PM
John@scc's Avatar
John@scc
I didn't do a timing test. The Check Engine light just came on itself a couple days ago, then it went off and now back on. So when I tested with a paper clip, I got 4 flashes then 2.
Is it possible the EST plug came loose? Where do I find the EST plug?
Old Aug 4, 2025 | 09:26 PM
Fly skids up!
It's a single wire weather pack connector near the distributor with a brown wire.
Old Aug 5, 2025 | 06:21 AM
John@scc's Avatar
John@scc
I have not seen one of those, but I'll look again for it.
Thanks for the reply.
Old Aug 5, 2025 | 11:09 AM
John@scc's Avatar
John@scc
I have 2 different brown wires.
Old Aug 5, 2025 | 11:15 AM
MelWff's Avatar
MelWff
Buy this book and follow the code diagnostics.
https://www.zip-corvette.com/82-shop...ce-manual.html
Old Aug 5, 2025 | 11:32 AM
Fly skids up!
It's the one in the first picture and it's connected. You'll need the FSM for this one.
Old Aug 5, 2025 | 11:47 AM
Eric P's Avatar
Eric P
Module , wiring or computer, back in the day we used to install a lot of modules for that code. it's cheap and easy enough to try and you're not out much money if it doesn't fix it
Old Aug 5, 2025 | 04:35 PM
70s's Avatar
70s
As others have said, you need the factory 1982 Corvette Shop Manual.
To OBD1 Code 42
