Bumpsteer - Measuring it & Correcting it
Mine was similar, car changed yearly over many years.
I may have run similar Hoosiers for a while. 275/45-16.
Those and the Yoko 008Rs worked much better once I pushed the wheels out to 10" wide.
Back to front suspension.
Once you go deep into the details, it turns into quite the saga, as usual.
I realized my new SPC A Arms had 1/2" taller ball joints.
So that caused me to deep dive into ball joints.
I was thinking about ordering some stock height ones, and some longer ones.
https://www.spcalignment.com/index.php/product/97160
SPC #97160. I ordered these because I could not get over 4* caster with any camber adjustment left, on my OEM control arms, even with my 1/4" slotted shafts. And I may want more caster or camber.
Easy camber and caster adjustment. Complete with 1/2" taller ball joints.
They offer a variety of ball joint heights:
- #97001: OE (Original Equipment) length stud.
- #97002: +0.25" over OE length stud.
- #97003: +0.50" over OE length stud. (comes std)
SPCs site does not even say.
So I ordered their poly bushing upgrade kit 92025
Jason Staley, and others, have successfully used longer B/J studs to increase the camber curve.
That seems like a very reasonable mod, and I wanted to document any bump steer changes.
SPC did not list a .75" or .9" Ball stud, one of which Jason used, so I called them.
Theirs stop at .5"
Well I could always get Howe right?
Wrong.
These are custom designed ball joints.
A tech finally measured one for me and they have a smaller than stock ball diameter.
Howe has nothing in that size.
Bummer!
I realized Jason used the older SPC arms, which use the bolt-in style of OEM ball joint.
SPC 94360 Arms also take 3 bolt ball joints
These use a std C3 Corvette ball joint that bolts in with 3 bolts.
OEM "correct" style sold by Corvette Vendors Corvette Central 572137
MOOG K6034 style
All of these have non replaceable ball studs.
But Howe make a version of the K6034 that is used for racing:
This is the Howe 22034S which is a direct replacement for a K6034, and it is rebuildable, and it has multiple stud lengths available.
It fits stock C3 A Arms as well as the other SPC arms.
It is available with multiple stud lengths up to 0.9", as a ball joint, or as replaceable studs.
Howe 223049 is the .9" taller version, 223045 is the .5" taller version.
Here are the replaceable studs:
So the sleek looking SPC 97160 arms take a custom designed ball joint, that has a 30mm / 1.181" diameter on the ball stud.
All the others take the K6034 style ball joints have a much larger 36.5mm / 1.437" diameter ball stud.
You can only get those custom ball joints from SPC, in only 3 heights, and they have a whopping 33% smaller friction area.
Not sure if I am going to keep them or not.
Need to regroup.
SPC makes these for multiple chassis, and the tech told me the curved arms and the taller ball joint are required on some applications. Trucks, B Bodies, etc.
But he had no info on Corvettes.
Yes it helps the car to go straighter by increasing the trail or the self-centering effect.
But it also increase neg Camber as you turn the wheel.
These are measured numbers.
Increasing the Caster will also increase the Camber as you turn the wheel.
You can gain a degree or more of negative camber as you turn the wheel for a roughly 45 mph turn, as Ignatz is doing above.
Static Camber + Camber Gain + Caster Gain - Body Roll = Dynamic Camber
It can let you run less static camber, which is better for braking.
There are many ways to wind up with zero to -.5 Camber at speed.
Duntov Racing Corvettes runs 7* Caster in their 800HP BB C3 Vintage race cars.
And as light as 350# springs.
But a perfect camber curve & bump steer curve.
I do not believe in making the car too stiff, BTDT.
Stiff was great on dry concrete, very go cart like. Very quick response.
But it was horrible in the wet, or in the bumps. Virtually uncontrollable.
Let that suspension work!
My 5-7* Caster goal is the main reason I will NOT consider a manual steering corvette.
Duntov Racing said they used to subscribe to the manual steering theory, but with 2* caster the driver got very tired arms in a race, and then they added power steering, with 7* caster, and the car is so much faster. And so much less tiring to drive!
And much easier to "catch" when the rear end slides badly. OOPS!
Like that will ever happen.
The steering arm drops ~1/8" (.118") for every degree of caster you add.
This is with the lower control arm held perfectly still
The Bump Steer blocks were 1" thick to improve the bump steer, and the GM '80 Power book says lower the tie-rod 3/4" to improve the bumpsteer.
But none of them mention how much Caster. I am assuming 1-2*, since both of them were likely dealing with manual steering.
Now with modern power steering, and 5-6-7* caster, we need a different bump steer correction.
The old "thumb rules" no longer apply.
Dunto said drop it 3/4". Guldstrand said drop it 1"
If both are talking about a MS car, with 2* caster, then our zero bump steer target should be around 1.0" to 1.25" down on the steering arm, from the 0 caster position.
That is not that much further down than what the 6* or 7* positions give me.
Maybe another .45"
Time to test.
It is an absolute waste of $ to put the fancy adjuster on the centerlink end. That will do absolutely nothing.
I spoke with Dan at Van Steel and he sold me just the parts shown below, for the steering arm end only.
Much less at $161
Specs: 7* caster, MS slow ratio steering arm hole, .625" spacers on Van Steel Bump Steer kit. But it only lowers the tie rod .49" from before, the rod end is different too.
Bump Steer total is maybe .060-.080" over 5 inch of travel. Or somewhere around .016" per inch.
Let's call this a success!
The very first measurement had .825" of movement over 5 inches, for .160" per inch.
More measuring and more graphs after the holiday.
I do like the way the dial indicator barely moves now, vs the first time when it spun like a tornado!
Only .006" toe change at 1" bump and .010" at 2"
That is race car territory!
I will do the other caster values later. And make a graph and/or a table for you.
I do not expect the 5* Caster values to be very much higher, maybe a little, it may still be under .040" bump.
Most of the toe change is now on front end rebound, about .020" per inch. But who cares the front end is up in the air anyway!
Ok a drag racer would care.
These are the ones I installed to get my tie rods to sit level after lowering the front end.
Detail
Van Steel maybe?
If you have some where from 5-7* of caster, that should take almost all of your bumpsteer out.
What I am attempting to do is to make a chart, that guys can use, without having to actually use a bumpsteer gauge.
I guess I better place my order before they get the notion to raise their price.
Detail
1) you don't have to drill out your original arms to accept the bolts provided
2) you can keep your fast steering setting
I kept my originals and here's a chance to fix the steering ratio lost.
Have a ton of work to do on the car when the weather gets better and this is an easy one! Thanks Leigh for starting this thread.
On their own they appear to place the tie rod between the two original holes, but that would only reduce the ratio if the blocks were installed perpendicular to the tie rod.
Looking at ignatz's picture from above, they're actually installed at an angle relative to the tie rod. The tie rod, new hole location, and power steering hole location are all right in line with each other, which means the ratio would be the same (while driving straight).
That would change as the front wheels turn more. The inner wheel would begin to steer faster than the power steering hole while the outer would steer slower because that's what Ackerman does. So maybe they slow things down a tad at higher steering angles (since the outer tire will determine the turn radius), but not all the time.
Am thinking of adding this modification to the steering to dial it out.
http://www.speedwaymotors.com/Adjust...Heim,3333.html
This would allow the tie rods to be level rather than sloping up and cure most of the bump steer potential.
Would need to get solid threaded tie rods at same time.
I dont like the VB&P or Gulstrand kits as it appears you need to drill out the taper of the steering arm to mount them so there is no going back.
They may have been what I purchased but they look a bit different to the ones on my 71. When I get home I will check, but the Van Steel ones look similar to mine and any will do the job.
And VBP tubular adjustable tie rods.
The new rod ends are a little shorter than before, so I just ordered some new 1" longer tubular rods from Speedway, as well as some bump steer studs with longer shafts.
I have more experimenting and documentation to do.
This stuff is so easy to do on a bare frame, with no body, springs or shocks in the way.
It would be so much more difficult later! LOL
Basically I want to come up with a couple of charts, so if, or when, I change the alignment, I can re-correct the bump steer by doing "X". I did something similar back when I was racing.
I might as well document and publish the charts along the way, so that others could just follow the "recipe" and enjoy corrected bump-steer, and could do so on an assembled car, without the need for all the measuring or disassembly.
That's the plan anyway, let's see if it works out.
I am glad a couple of you are following along!
BTW: I have had some great conversations with Dan at Van Steel in the past. We have discussed me helping him prototype a part or two for them. I should talk to him about this as well.
