Transverse leaf spring Rubber
Old Dec 9, 2025 | 05:02 PM
cottoneg's Avatar
cottoneg
Default Transverse leaf spring Rubber
I am cleaning all my hardware. Replacing things like spent nyloc or lock washers.
One thing I did notice while cleaning the big bolts that are at the end of the transverse leaf spring. The rubber is hard and started to crack.
Should I buy rubber again or one of the many other materials??? My guess is I can’t see how it matters. But figure I ask.
Old Dec 9, 2025 | 05:35 PM
Alan 71's Avatar
Alan 71
Hello,
The rubber bushings at the ends of the rear spring are under a lot of pressure.
Replacing them would be a good idea.
Be careful!!!
Regards,
I'd recommend replace both the bushing at the spring and the one at the trailing arm.
Old Dec 9, 2025 | 08:09 PM
cottoneg's Avatar
cottoneg
Originally Posted by Alan 71
Hello,
Be careful!!!
Regards,
Thank you for the warning! Thankfully they are out. My intention is to replace all four! What would you replace them with? What site would you purchase them from. I have not had luck with Chinese parts.
Old Dec 9, 2025 | 08:19 PM
interpon's Avatar
interpon
I used these..worked great and 🇺🇸..at least they were..
https://www.energysuspensionparts.com/3.2104
Old Dec 10, 2025 | 03:06 PM
Alan 71's Avatar
Alan 71
Hello,
I believe 2 good sources would be Bairs or Van Steel.
Regards....
Old Dec 10, 2025 | 03:16 PM
Eliredandblack's Avatar
Eliredandblack
If your springs are OEM then it would be a good idea to have them restored (if want to keep everything original to your car). I had a Corvette Shop remove the springs and they took them to a Truck Spring Shop to be restored, I bought a set of the rubber pieces that go between the leaves of the springs.
Old Dec 11, 2025 | 07:27 AM
cottoneg's Avatar
cottoneg
My car is far from OEM. I have had the stock springs, the Daytona springs and now F-41. Through it all, I had the original rubber. With the diff and arms out for repair, I had an opportunity to see the rubber and it is in need of replacement.
Old Dec 11, 2025 | 07:28 AM
cottoneg's Avatar
cottoneg
Thank you! I ordered from them yesterday.
Old Dec 13, 2025 | 01:45 PM
Crimson Thunder's Avatar
Crimson Thunder
Here is the part numbers for the Energy Suspension bushings.
To Transverse leaf spring Rubber
