C3 center gauges removal
Old Feb 9, 2026 | 04:16 PM
Sixty6chevy's Avatar
Sixty6chevy
5th Gear
Default C3 center gauges removal
Anyone know where to get an original clock rebuild? https://youtu.be/pXU-1xGOJzA?si=auY7BZwt6EWTF6Wj
Old Feb 9, 2026 | 04:23 PM
Alan 71's Avatar
Alan 71
Hello,
D&M Restoration in Greenville, South Carolina has a good reputation.
Regards...
D&M Restoration
57-B Creekside Park Court
Greenville, SC 29615
864-254-9989
support@dandmrestoration.com
Old Feb 9, 2026 | 04:44 PM
Sixty6chevy
5th Gear
Default Thank you kindly
Clock rebuild on the way!
Old Feb 9, 2026 | 05:02 PM
interpon's Avatar
interpon
you can also fix yourself.. probably bad contacts. here is my experience. getting it out is more than half the battle..
https://www.corvetteforum.com/forums...ck-repair.html
Old Feb 9, 2026 | 07:08 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
mine was a weak rewind spring and just being dirty... Cleaning and oiling with a clock oil does wonders. MIne loses a second every 2 or 3 days if I remember correctly. Its been ticking away beautifully on a power supply for a couple of weeks now.
Old Feb 9, 2026 | 10:01 PM
Sixty6chevy
5th Gear
Default The clock is out
I will have to open it up and take a look ! Thanks
Old Feb 9, 2026 | 10:35 PM
gcthree's Avatar
gcthree
When I took apart the interior of my '71, the clock had a sticker on the back. I suspect it was done a dozen or so years ago....
Corvette Clocks by Roger
3216 West Blvd.
Belleville, Ill 62221
618-234-0488
Old Feb 11, 2026 | 08:58 AM
pltmgr's Avatar
pltmgr
Ive filed the contacts and cleaned the mechanism with success on a number of clocks. Some choose to convert to a quartz movement. I have one in my 66. Since all my collectibles have battery disconnects I do not fool with any of the clocks - don't want to reset them every time I drive.
To C3 center gauges removal
