1971 Headlight switch vacuum lines
Old Apr 5, 2026 | 08:46 AM
Primoz's Avatar
Primoz
2017 C3 of Year Finalist
Default 1971 Headlight switch vacuum lines
We finally broken in the engine on my 71 and when I tried to test if headlights open, they don't.
Since everything is hooked up under the bonnet and the headlight switch worked when taken off, I am thinking I hooked the vacuum lines wrong on the headlight switch.
Can someone share some insight and photos of how it should be hooked up?
I was working on a schematics from Willcox but I noticed that there are several out there and that the information is opposing.
I am attaching the photos of how I hooked the lines up.
Old Apr 5, 2026 | 09:29 AM
Alan 71's Avatar
Alan 71
Hello,
The electrical and vacuum connections.
Regards...
Old Apr 5, 2026 | 09:49 AM
robertea's Avatar
robertea
This drawing is for my 69, but I don't think much changed until 73 when they got rid of the wiper door. It is possible that the hose colors might have changed, but I think the routing would be the same.
Old Apr 5, 2026 | 09:51 AM
Primoz's Avatar
Primoz
Originally Posted by Alan 71
Hello,
Regards...
Alan, unfortunately no photos are displayed.
Old Apr 5, 2026 | 09:54 AM
robertea's Avatar
robertea
When I first looked at this record there was an image attached to Alan's reply. Don't know where it went. Things do disappear on the Forum occasionally.
Old Apr 5, 2026 | 10:45 AM
Primoz's Avatar
Primoz
Hello,
Regards...
I am already lost. Can you post some photos of vacuum override switch just to make sure I get it correctly?
I used this schematics:
Old Apr 5, 2026 | 10:49 AM
robertea's Avatar
robertea
It appears that your hoses are reversed on your headlight switch. That is one of your issues.
Old Apr 5, 2026 | 10:59 AM
Dave J's Avatar
Dave J
Follow this simple rule. Vacuum source hose ALWAYS connects to the port closest to the pull **** on headlight switches and over ride switches. Unfortunately there are some vacuum schematics out on the webs that are not correct.
Old Apr 5, 2026 | 11:36 AM
Alan 71's Avatar
Alan 71
Hello,
I'm sorry I didn't get the photo to show.
I was I a hurry to leave for church.
I added it to my original post now.
Regards.....
Old Apr 5, 2026 | 12:45 PM
Peterbuilt's Avatar
Peterbuilt
Sometimes the AIM is misleading.
Old Apr 5, 2026 | 01:03 PM
Alan 71's Avatar
Alan 71
Hello,
This is the same drawing that primo posted.
Note the 't' and short yellow hose. This noted in the photo I posted.
I think this is what makes THIS drawing different from the one that Robertea posted.
I'm sorry I confused things
Regards....
Old Apr 5, 2026 | 01:32 PM
Primoz's Avatar
Primoz
Switched the hoses at the headlight switch.
Of course they were reversed.
Of all the diagrams I had printed out the Paragon, Zip, Doc Rebuild & Willcox ones were correct.
And I decided to follow the AIM which is misleading.
Thanks to all for the help.
I hope now everything will work correctly.
To 1971 Headlight switch vacuum lines
