Be Cool
Old May 22, 2003 | 07:36 PM
78 Vette's Avatar
78 Vette
Default Be Cool
Just picked up a Be Cool radiator. They gaurntee 20 degree drop is it true? Sounds good but we will find out this weekend. What do you think? :steering:
Old May 22, 2003 | 08:15 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Default Re: Be Cool (78 Vette)
It will only drop as low as the thermostat is rated for :D
Old May 23, 2003 | 09:53 PM
78 Vette's Avatar
78 Vette
Default Re: Be Cool (BSeery)
I currently have a 180 my car runs at 210 with a stock rad. That's with a edelbrock pump. The current rad doesn't have enough cooling capacity so it will never run at 180. I would like to see it meet there claim if possible. I Just wanted to see how many people have had these results if any. And what type of fan they are running. I currently have a 7 blade with a bbc clutch.
Old May 23, 2003 | 10:07 PM
zwede's Avatar
zwede
I love the be-cool. I have their direct fit + edelbrock w-pump, dex-cool, spal fans and a 78 overflow tank. I have no mechanical fan (=tons of room in the engine compartment). On a 70F day the fans will never even come on. If I sit in traffic on a hot day with AC on, the temps slowly climb to 200F where the fans come on and it drops back to 180F within 3-4 minutes. Couldn't be happier. It's a big-block, too.
Old May 23, 2003 | 10:15 PM
78 Vette's Avatar
78 Vette
Default Re: Be Cool (zwede)
Wow glad to here something positive thanks for the input. I have a pretty radical 383 i drive it everyday so cooling is a issue. :cheers:
Old May 23, 2003 | 10:49 PM
467-Ratman's Avatar
467-Ratman
My 2 cents worth on the BeCool product, you will be impressed with it for sure. My 454 BB is .60 over at 467 cubes and I have heard that the big motors always run 220 plus for temp, well I have the BeCool radiator with Stewart water pump and 160 stat, I have twin Spal fans. My fans come on at 195 and go off at 180 or so, even in 90 degree weather at idle it never goes over 195! Great product, good service, good people equal many smiles, enjoy!
Old May 23, 2003 | 11:36 PM
78 Vette's Avatar
78 Vette
Default Re: Be Cool (467-Ratman)
Thats pretty impressive. Im going to install it next week. My vett is my daily driver my other car (street/race) is a 67 nova with a bigblock dart heads 630 lift solid cam 11.00 comp turbo 400 trans brake 411 and lots more. Its hard to keep it under 200 Thanks for your input.
Old May 24, 2003 | 09:51 AM
flynhi's Avatar
flynhi
Even with all the HiPo cooling stuff (BeCool, Stewart, Spal) you still need to have a functional chin spoiler and foam seals around the rad and on top of the rad frame to seal to the hood.
I also had some cooling effect from removing my front license plate.
Old May 25, 2003 | 09:27 AM
78 Vette's Avatar
78 Vette
Default Re: Be Cool (flynhi)
Yep i found that out on my Trans Am about 5 years ago. Thats all new on the vett I think I got it from ecklers. :thumbs:
Old May 25, 2003 | 09:41 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
A new aluminum radiator will definately do wonders for your cooling problems. You will be well pleased when you get it installed.
Old May 25, 2003 | 10:12 AM
78 Vette's Avatar
78 Vette
Default Re: Be Cool (Eddie 70)
I may install it today. If I do I will post my results. My next project is a 4l80e and 370 gears. I just want to thank everyone for there input :cheers: .
Old May 25, 2003 | 06:36 PM
gravismaximus's Avatar
gravismaximus
scince ive insalled mine, my eletric fan does not come on, very pleased with BE COOL
Old May 26, 2003 | 10:48 AM
78 Vette's Avatar
78 Vette
Default Re: Be Cool (gravismaximus)
Its in it looks liked it may have helped it ran at about 190 instead of 215. But its still not running at thermostat temp 180. I installed the thermostat with the radiator so they are both new. I am thinking that the ac condenser is to restrictive or the clutch fan just doesn't pull enough air. I wanted to keep the a/c but if I have to I am going to pull it out :cry My other option is duel fans I don't mind spending 300 dollars if there is some kind of guarantee it will help. Dose anyone know the cfm rating on a stock fan? (7 blade bbc fan) :cheers:
Thanks for all you input John
Old May 26, 2003 | 11:13 AM
zwede's Avatar
zwede
Are you sure your gauge is accurate? See my post above about my combo. It runs at 180F.
Old May 26, 2003 | 11:24 AM
78 Vette's Avatar
78 Vette
Yep when the car is cold it goes up to 180 cools down then it creeps up to about 190, 195 So the gauge seems to be good ( VDO gauge) And i havent hit a hot day yet. It seems to be a air flow issu but maby im missing something.
Old May 26, 2003 | 12:39 PM
flynhi's Avatar
flynhi
Stock fans don't have CFM ratings since fan speed is variable with engine RPM.
Old May 26, 2003 | 12:43 PM
flynhi's Avatar
flynhi
Check the installation of your fan. It is possible to install the fan backwards (don't ask me how I know this...) The fan will have the word "front" stamped into the steel hub. This word should face forward.
To Be Cool
Old May 26, 2003 | 01:26 PM
XLAR8R's Avatar
XLAR8R
I am having a similar problem. Mine came with one electric fan that
runs all the time (no thermostat hooked to the fan). And it still gets
up to the 220 mark. Wondering if I need some kind of shroud ?
Old May 26, 2003 | 06:15 PM
78 Vette's Avatar
78 Vette
Default Re: Be Cool (7T9L82)
Its in right. How do you know lol I will get it to lock onto 180 one way or another and I will tell you guys how I did it.
Old Jun 1, 2003 | 05:02 PM
78 Vette's Avatar
78 Vette
Ok I did it Installed the radiator it ran at 190 better but the thermostat was hanging open at 190. So I removed the A/C condenser and advanced the spring on the clutch fan. Now it runs at 180 and I can keep my hand no the radiator when it is at full operating temp. :cheers:
