Synthetic Oil User question?
Old Jun 8, 2003 | 09:11 PM
Smokehouse69's Avatar
Smokehouse69
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Synthetic Oil User question?
How often do you guys change your oil? I doubt I'll drive more than 3 or 4 thousand miles a year in my 'vette, so is it OK to only change it one time a year?
Old Jun 8, 2003 | 09:25 PM
467-Ratman's Avatar
467-Ratman
Default Re: Synthetic Oil User question? (Smokehouse69)
I am running Royal Purple in my 454, works great and I am planning on changing it every year also. It costs about 5 bucks a quart but I think its worth it. No problem on 3 to 4k miles a year, with todays oils and high quality filters you can go 4k miles no problem.
Old Jun 8, 2003 | 09:29 PM
Rolling Thunder's Avatar
Rolling Thunder
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '03
Once a year does it in my 95 ragtop since it only gets about 3000 or 4000 miles put on it.
Great to see you back!
Dave
Old Jun 8, 2003 | 09:36 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
Unless you drag race all the time, I don`t see why you can`t go 3-5000 miles on a synthetic oil change. I use Mobil-1 in my Vette,my S-10, & my `02 Harley Road King. I would not go beyond 5000 miles before changing the oil. Even though synthetics are said to stand up to wear & temperature extremes better than dino oil, they still get contaminated by blowby, condensation etc. :)
Old Jun 8, 2003 | 10:39 PM
zwede's Avatar
zwede
Default Re: Synthetic Oil User question? (kenv)
Changing synth every 5k miles is a waste of money, but if it makes you feel better...
Here's a guy who sends a sample in for analysis every 1000 miles. He will continue until the oil tests bad. He's currently at 11000 miles, and the mobil1 oil still tests ok!
I run mobil1 and change it around 7-8 k miles.
Old Jun 8, 2003 | 11:45 PM
flynhi's Avatar
flynhi
Default Re: Synthetic Oil User question? (zwede)
Ditto Zwede. Use high quality filters - Mobil or Amsoil.
Old Jun 9, 2003 | 12:03 AM
Smokehouse69
Default Re: Synthetic Oil User question? (flynhi)
Thanks guys you just confirmed what I thought. This was my third oil change on the ZZ-4 and the first with synthetic. One thing interesting I noticed while breaking the engine in, the first oil change, after 100 miles I noticed a clump of iron filings (about 1/4" ball) stuck to the magnetic drain plug. After the second change at 500 miles, there were about half as many stuck to the plug. This time with 2000 miles on the oil, there were no noticeable filings stuck to the plug.
Old Jun 9, 2003 | 06:28 AM
69er's Avatar
69er
Active Streak: 90 Days
Steve
I go with 10w40 Amsoil and do about 2500-3000 miles a year and change oil and filter once a year on my two year old rebuilt engine.
[Modified by 69er, 6:29 AM 6/9/2003]
Old Jun 9, 2003 | 06:31 AM
Mystery Machine's Avatar
Mystery Machine
I change it about 3K or so. I'm using Mobil 1 oil and filter.
Old Jun 9, 2003 | 11:10 AM
Glutamine83's Avatar
Glutamine83
Default Re: Synthetic Oil User question? (Mystery Machine)
i use 15W-50 Mobile 1, and will probably change every 5000Km
Old Jun 9, 2003 | 11:14 AM
Fevre's Avatar
Fevre
Default Re: Synthetic Oil User question? (Glutamine83)
One good thing about changing it more often is that if you have a mag drain plug, you can keep an eye out for excessive metal in the oil. Figure even at $50 an oil change with syn, changing it at least twice a year is not that expensive compared to your eng going south.
Old Jun 9, 2003 | 12:27 PM
Smokehouse69
Default Re: Synthetic Oil User question? (Fevre)
Good point Chris! I'll keep that in mind.
Old Jun 9, 2003 | 12:51 PM
BeaterShark's Avatar
BeaterShark
I change mine out at 5k miles, but that just because it's easy to look at the odo and know when I need to change it. I'd go longer if I could come up with a way to remember the change.
Here is the site for the info zwede was talking about: http://neptune.spacebears.com/cars/s.../oil-life.html
Old Jun 9, 2003 | 03:48 PM
yogi78's Avatar
yogi78
I change mine twice a year because I don't put that many miles on it either. But I don't like the only once a year idea because the oil picks up acids and contaminents from the combustion process and I don't like that sitting around in my motor eating it up internally. I read somewhere that it was real important to change the oil before the car sits for any extended period for this reason.
To Synthetic Oil User question?
