" I know the hook ones are not good for the body but they have the ones that go completely under the body and up the other side."
I have the "hook type" and didn't have any problems. I placed a 2X4 between the straps so it took the sideload off the doors. I also used a strap on the nose at the same time.
Unless your body reinforcements are all rotted (rocker channels/door pillars/
windshield frame), the body lift with hooks is fine. If the birdcage is all rotted
to hell, then slinging a nylon strap under the car can work - but it's no picnic.,
