Checkered Garage Floor..
Old Jan 10, 2004 | 10:56 AM
  #41
HankB1's Avatar
HankB1
Default Re: Checkered Garage Floor.. (GrandSportC3)
NICE, like pulling into the winner's circle every time. All you need is a couple of 'Winston Cup' babes to greet you !
Old Jan 10, 2004 | 10:59 AM
  #42
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default Re: Checkered Garage Floor.. (HankB1)
Now I just have to find those :D :D
Old Jan 10, 2004 | 11:15 AM
  #43
GrandSportC3
Here are 2 more pics of my cars in the garage...
Old Jan 11, 2004 | 11:04 AM
  #44
terryrudy's Avatar
terryrudy
Default Re: Checkered Garage Floor.. (LakotasRose)
Looks familiar Olivier. :) I used home depot tile for mine though. About $350.
-terry
Old Jan 11, 2004 | 11:18 AM
  #45
GrandSportC3
Default Re: Checkered Garage Floor.. (terryrudy)
-terry
Are those 2 feet x 2 feet??
Old Jan 11, 2004 | 11:50 AM
  #46
sammyb's Avatar
sammyb
Oliver,
Did you have any concerns about not being able to locate fallen parts quickly on the black paint? I'm planning to do my garage (a wide-3 car garage,) but since I do so much tinkering, and I have hands like bricks (I'm a drummer -- no finger independence!) I tend to drop screws and bolts.
I plan to do the floor in light gray so I can find the stuff I drop...unless you say that you can still find oily bolts on the floor on the black.
Sam
Old Jan 11, 2004 | 12:09 PM
  #47
terryrudy's Avatar
terryrudy
Yeah the squares are 2' x 2' but I used 1' x 1' squares and put 4 of them together.
-terry
Old Jan 11, 2004 | 12:19 PM
  #48
Cali,68,L-79's Avatar
Cali,68,L-79
Default Re: Checkered Garage Floor.. (78Vette-SA)
i'm planning on doing the same thing. One I have 2 months of painting the inside of the house first. Then i'm spakling the walls and putting a semi-gloss white over the walls and ceiling after which i'll do the squares. Should look nice. one problem I first have to figure out is a pulleyt system to suspend the hard top over the Vette to allow me to raise and lower the hard top by myself. Yeah I know there are motorized kits but I'm making my own. 2 two by fours bolted into the studs above with three pulleys fore and aft with pipe insulation around the lifting straps. the 3rd pulley will tie the 2 main lpulleys into the lifting line which will use a sailboat non-slip chock to hold the hard tops weight. Once that's built I can start painting.
Old Jan 11, 2004 | 12:36 PM
  #49
GrandSportC3
Default Re: Checkered Garage Floor.. (sammyb)
Oliver,
Sam
no problems with locating parts on the black squares so far :D
Old Jan 11, 2004 | 12:38 PM
  #50
GrandSportC3
-terry
:thumbs: :thumbs: :thumbs:
Old Jan 12, 2004 | 06:30 AM
  #51
guppie's Avatar
guppie
St. Jude Donor '08
:thumbs: Awesome looking floor :cheers:
Old Jan 12, 2004 | 06:52 AM
  #52
groovyjay's Avatar
groovyjay
Default Re: Checkered Garage Floor.. (guppie)
Very :cool:
Old Jan 12, 2004 | 07:45 AM
  #53
norvalwilhelm's Avatar
norvalwilhelm
Default Re: Checkered Garage Floor.. (groovyjay)
Looks good but now you will be paranoid about scratching it when using a jack or sliding any heavy object across the floor. :) :lol:
Old Jan 12, 2004 | 08:55 AM
  #54
tersian's Avatar
tersian
Default Re: Checkered Garage Floor.. (norvalwilhelm)
Those home depot tiles, are they the self-stick or were they normal linolium tile?
Old Jan 12, 2004 | 09:17 AM
  #55
GrandSportC3
Default Re: Checkered Garage Floor.. (tersian)
I looked at those and they are self-stick..
Old Jan 12, 2004 | 09:18 AM
  #56
GrandSportC3
That's not a problem.. Paint can be touched up easily :D
