My engine...thoughts....comments?
Old Jan 26, 2004 | 10:18 AM
SilveroverBlue81's Avatar
SilveroverBlue81
Default My engine...thoughts....comments?
Here is the engine modifcations I am going to do, one question though does anyone know what size valve springs I am looking for. If anyone sees anything I missed let me know (kn heads, was hard enough to talk the wife into this much)....
:crazy:
Comp Cams Magnum Roller Rocker Arms
Edelbrock Performer (EGR) 3706 Intake manafold
Edelbrock Accu-Drive® camshaft gear drive
Comp Cams High Energy Hydraulic Lifters
Comp Cams Magnum Pushrods
Comp Cams 268 High Energy Camshaft
HEI Super Coil
March Performance Underdrive System
Steward Hi-Flo Water Pump
Hypertech Thermo Master Power Chip
Old Jan 26, 2004 | 10:23 AM
Gordonm's Avatar
Gordonm
Default Re: My engine...thoughts....comments? (SilveroverBlue81)
The springs according to my Comp Cams book are 110 pounds on the seat and 285 open load. They are 981-16 Comp Cams parts no. You could have saved some money by not getting a gear drive for the cam and with that cam roller rockers are not needed. If you already have them it is not going to hurt anything.
Old Jan 26, 2004 | 10:35 AM
Ganey's Avatar
Ganey
James
Get a roller timing set. Roller rockers are not needed, get roller tip. Stock springs are fine for 1.52.
You should state trans. & rear gears & whether you are doing a complete rebuild.
Old Jan 26, 2004 | 04:03 PM
LFZ's Avatar
LFZ
Default Re: My engine...thoughts....comments? (Gordonm)
just curious, whats wrong with having the gear drive? wondering because i thought about getting a gear drive from my 350 with that same cam.
Old Jan 26, 2004 | 06:28 PM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
That all sounds pretty good to me. I also agree that a gear drive is pretty much overkill. Especially for a street engine (and many race engines). You will like the 268. It is a great cam. It sounds nice and makes good power.
Old Jan 26, 2004 | 07:40 PM
zwede's Avatar
zwede
Gear drives are very noisy and get old real quick on the street, unless you happen to like the whining.
Old Jan 26, 2004 | 07:55 PM
corvtt1969's Avatar
corvtt1969
Default Re: My engine...thoughts....comments? (zwede)
i didnt see a super charger or turbo on that list.... :jester
Old Jan 27, 2004 | 09:19 AM
SilveroverBlue81
Default Re: My engine...thoughts....comments? (corvtt1969)
I want to keep it looking as stock as possible
Old Jan 27, 2004 | 09:21 AM
SilveroverBlue81
I actually like the whine, have you had one and if so does it make and difference in the preformance? :steering:
Old Jan 27, 2004 | 09:33 AM
SilveroverBlue81
Default Re: My engine...thoughts....comments? (Ganey)
Thanks for the advice, but it looks like the cost would be more, is there that much of a difference in preformance?
To My engine...thoughts....comments?
