Interior Rust shots finally
Right side is rusty too and I am posting a pic where you can see rust in the dash pad area. I don't want my new carpet to get wet when I wash the car, so hope somebody can allow me a suggestion or two?
Leak #2 was where several fiberglass panels are bonded together in the cowl, just below the pass side wiper arm mount. Factory sealer was dried and cracked and let water in. Some new sealer took care of it.
Good luck.
I really don't think you need a big leak to accumulate enough water to do that. In my experience, those plugs in the center let more water in than they'll ever let out. And then once it soaks into that jute backing, it's hard as hell for that water to get back out. My car sat in a 100+ degree Florida garage for about half a year before I got around to pulling up the carpets. The car had been driven maybe twice (not in the rain) in the meantime. And there was still enough water in the jute for me to be able to wring it out.
My theory is even if you don't have a "leak" per se, enough water can sneak in around that plug, from around the door seals, from wet shoes, etc. to eventually saturate the jute over the decades. So rather than begin a witch hunt for a leak, I just waterproofed my floorpans. I ground off all the rust, hit the pans with rust convertor, and then put 2 coats of rubberized undercoating on them. I also made sure to seal down the plugs with the undercoating. As I've told others, if they rust again, it won't be from the inside.
I figure ...
1. I ain't putting that damn jute back in. I'll use some manner of non-absorbent padding if at all.
2. I don't drive in the rain.
like in vans, those black rubber mats cause the rust problems on floorboards to total the van in about 5-6 years or less, depending on useage....
GENE
Thanks much for the help.
I'm rounding up the interior parts I can lay hands on now and trying to get her together this weekend. Man that dash is a Major PITA!
Take a wire brush or DA to the rust and I bet you find glass under it.
Hans
Then I discovered POR-15 and the Floor pan & trunk resto kit, with its amazing epoxy putty.
add on the Power Mesh reinforcing Fabric and top off with Por-15 black and...
