Paging Lars......
Old Sep 23, 2004 | 10:00 AM
Greg's Avatar
Greg
Just another Corvette guy
Default Paging Lars......
The threads on the body of my 7040507 are stripped at the fuel filter fitting. Can you help?
Thanks,
Greg
Old Sep 23, 2004 | 10:46 AM
lars's Avatar
lars
If your carb is the early style carb with the 7/8"-20 inlet fitting I can fix it. I cannot fix the later 1"-20 fittings. The 7/8-20 fitting is identified by a black sealing washer located just under the hex head portion of the fitting (seals on the outer surface of the carb). The 1"-20 has a nylon seal in a flat surface at the end of the threads (seals inside the carb). Your carb number is for a 1970, and this should have the 7/8-20 fitting. Drop me an e-mail for specific info, costs and shipping instructions:
V8FastCars@msn.com
