Remember the peeling Hookers??
Old Oct 23, 2004 | 07:01 PM
Twin_Turbo's Avatar
Twin_Turbo
Originally Posted by trotter73
I can't believe Hooker would put their name on something that would rot out in a year.
I do believe it, the hookers I bought for my truck were like that also, the engien didn't run lean or too rich but the coating is junk. Since I had no chance of ever getting any kind of customer service over here I blasted them and had them chromed, held up pretty good since then.
Old Oct 23, 2004 | 08:29 PM
Megawatt's Avatar
Megawatt
I have Hooker super competition headers on my 406. They were coated by High Performance Coatings (HPC). The coating has not held up very well. I live in a climate with high humidity and I park under a car port so maybe that has something to do with it. I have noticed that the further from the exhaust port (higher heat nearer the exhaust port) the worse the coating is. I also noticed that in the tight areas between the tubes the coating has faired the worst. I believe they spray the coating on so it may be difficult to get to these tight areas. I also noticed that the drivers side header under the oil filter seems to be the worst. Maybe I let some oil drip when changing filters which may contaminate the coating with carbon and caused it to fail. I forgot who coated my headers so I had to look through a file of invoices to find it. I can’t believe how much money have spent on this project. I wished I hadn’t done this search. Don’t want to know.
Old Oct 23, 2004 | 09:00 PM
Megawatt's Avatar
Megawatt
Old Oct 23, 2004 | 09:25 PM
trotter73's Avatar
trotter73
I was about to buy Hooker ceramic sidepipes and headers, just got my STS baffles.
Now I don't know what I'm going to do after reading all these bad reviews.
Old Oct 24, 2004 | 12:43 AM
codestar7's Avatar
codestar7
Default Ceramics
There is a high heat (1200 degrees) paint that you can buy literaly at the Auto Zone, I like the white color. I've used it several times on headers with a long lived success, up to 5 years with no rust...good stuff!
Old Oct 28, 2004 | 01:15 PM
Ozzie71's Avatar
Ozzie71
Go for Stainless. I did. Less than $100 more than jet hot and will last for ever. The headers turn yellow close to the engine (no big deal) but the visible pipes are awesome. I thought they sent me chrome by mistake, had to check with a magnet to be sure. Been on the car 6 months and very happy so far. Also got STS baffles and heatshields, look great and no burns.
Cheers
Mick
Old Oct 28, 2004 | 01:23 PM
LOTAHP's Avatar
LOTAHP
Originally Posted by rosslato
u should go w/jet-hot. they have 3 locations in the U. S. it cost me around $350 not including the shipping. yours will probably be cheaper since they don't have to dechrome them. the bigest PITA was trying to find boxes big enough to ship the headers. took em about 10 days to get em back to me. was in awe when i opened the boxes. put some chrome cleaner on em and then some wax and they really shined up nice
JET-HOT will ship you boxes FREE to ship your headers back to them
Old Oct 28, 2004 | 01:24 PM
exdrag77's Avatar
exdrag77
I would like to hear how you made that work?! I bought that Dupli Color 1200 degree spray paint, applied to my headers per directions and baked in my oven at 400 degrees for a couple hours. When I put the headers on and fired the car, they immediately blistered! That was quite a few hours worth of work wasted!
Old Oct 28, 2004 | 03:27 PM
flood's Avatar
flood
Stainless is the way to go. Besides I like how it changes to gold/purple.
I am suprised to see that the ceramic coat doesn't hold up.
Old Oct 28, 2004 | 07:41 PM
Megawatt's Avatar
Megawatt
My opinion is ceramic coatings are not durable no matter who does them. I bought my headers from Hooker and had them coated myself by HPC so I can't blame Hooker. I'm convinced the way to go is stainless first and chrome plating second. But where do you get full lenght 1 3/4" primary headers in stainless? I've seen the shorties in SS but not the full length.
Anyway, ceramic coated headers not holding up is another "lessons learned" for me.
Old Oct 28, 2004 | 07:55 PM
Summerfun's Avatar
Summerfun
I made the 1500 degree paint work!!
I had the peeling Hookers blasted with Aluminum Oxide (I think).
Apparently the blasting particles look like fiberglass particles....like little needles with sharp points on both sides.
Supposedly if you blast with this stuff, it will penetrate the metal quite deeply instead of just creating a smooth surface like kitty litter does.
Larger kitty litter makes a rougher surface and smaller kitty litter a smoother surface....if you catch my drift
Anyway, the idea is for Aluminum Oxide to create a sponge effect so that your paint will "soak" into the metal and then "Bond" with it when you bake it!
Sounded good to me, so I went with it and the cream headers and black sidepipes are holding up pretty good so far.
BTW I am waiting for more black 1500 degree paint to paint the headers that are sticking out the side of the car black like the side pipes.
I have my very own Bubba-ized mobile for a little while
Old Oct 28, 2004 | 09:09 PM
exdrag77's Avatar
exdrag77
Thanks for the info. I put the 1200 degree over acetone wiped black summit headers and that may have been why it peeled/blistered even though baked on!
Old Nov 2, 2004 | 01:42 AM
  #33
codestar7's Avatar
codestar7
Default Paint
Ummm, Well I never did anything special. I sand blast the headers and slow bake in the oven at 400 degrees? 1500 degree paint, I used the white .........What can I say?
Old Nov 2, 2004 | 04:32 AM
  #34
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
I really like the white pipes on these racer's. Think that's what I'll do. Remind me of what they use to call a "cafe' racer." Hmmm, maybe I can get some red/white paint too.
I think 67Heaven's C2 had these years ago. Check out how much shorter the pipes are on the red C2.
Old Nov 2, 2004 | 08:27 AM
  #35
comp's Avatar
comp
Cheers
Mick
pic's
Old Nov 2, 2004 | 08:31 AM
  #36
comp's Avatar
comp
done the same thing ,didn't have pipe's Completely clean and also was runnning lean and raise temps.
Old Nov 2, 2004 | 01:22 PM
  #37
Ozzie71's Avatar
Ozzie71
Originally Posted by comp
pic's
Here ya go.
This is my first attempt at posting a pic. Hope it works.
To Remember the peeling Hookers??
Old Nov 2, 2004 | 01:32 PM
  #38
Ozzie71's Avatar
Ozzie71
Here is another.
Cheers
Mick
Old Nov 2, 2004 | 01:50 PM
  #39
BigBlockk's Avatar
BigBlockk
Ozzie71 is that color code 974 on that car. That is prity paint. My '70 is code 974. Boy, I hope it looks that good when I get it done. Nice car.
BigBlockk
Later.....
Old Nov 2, 2004 | 02:04 PM
  #40
Ozzie71's Avatar
Ozzie71
Originally Posted by BigBlockk
Ozzie71 is that color code 974 on that car. That is prity paint. My '70 is code 974. Boy, I hope it liiks that good when I get it done. Nice car.
BigBlockk
Later.....
The paint was on the car when I got it. It's not original, looks OK in photos, but it is bit rough up close. The car is not a bad 20 footer. The trim tag is missing so I don't know what the orig paint code is.
Sorry I can't be of much help. Originality doesn't worry me. The car is a 71 with custom glass front and 68/69 fenders, but I like the look.
Cheers
Mick
