Motor Mounts
Old Oct 24, 2004 | 12:05 PM
Richard Cooper's Avatar
Richard Cooper
Default Motor Mounts
Can anyone tell me how hard it will be to change the motor mounts in a 1981 coupe? Must I disconnect anything or is there enough "slop" on everything to just jack up the motor enough to slip out the old ones and slip in the new ones? Thanks in advance.
Old Oct 24, 2004 | 12:35 PM
zwede's Avatar
zwede
I changed the mounts on my 71 BB recently and it was easy. You want to remove the distributor cap in case the engine tilts back enough to force it into the firewall. Otherwise, just jack the engine up, swap mounts and let it back down. Piece of cake. I lifted the engine under the oilpan with a big piece of wood between the jack and the pan to spread the load.
Old Oct 24, 2004 | 01:12 PM
Richard Cooper
Zwede,
Thanks, did you have to disconnect the tranny from the engine? Can I just jack them up together? Thanks again. Have a good weekend.
Old Oct 24, 2004 | 01:24 PM
Paul L's Avatar
Paul L
Richard,
Just do as Zwede said. You don't need a lot of clearance to slip them out.
Old Oct 24, 2004 | 02:25 PM
zwede's Avatar
zwede
Originally Posted by Richard Cooper
Zwede,
Nope, didn't have to disconnect anything.
Old Oct 24, 2004 | 05:40 PM
JoeRags's Avatar
JoeRags
Did mine today, had to remove the fan. When I jacked the up, the fan hit the shroud. After that, no problem.
Joe
Old Oct 24, 2004 | 06:52 PM
Richard Cooper
Thanks for all the replys. Its sure nice to know that there is a great place to go to get help. Thanks again.
Old Oct 24, 2004 | 09:35 PM
terry82's Avatar
terry82
i put a new poly motor mount in my 82 this year [drivers side ]no ,i did not have to disconnect anything .i did have some trouble getting everything to align back up .not hard just took time.
To Motor Mounts
