Lowering a C3
Old Mar 30, 2015 | 02:42 AM
qwank's Avatar
qwank
my bolts are inside, what you are seeing is the rear sway bar mount bolts
Old Mar 31, 2015 | 07:45 PM
digitfast10's Avatar
digitfast10
Cruising
Default Lowering C3
Do you know if I can put sway bar on mine
Old Mar 31, 2015 | 07:55 PM
Karsten's Avatar
Karsten
I replace the 42 year old front springs on my 1973 with 550 Lbs
http://www.ecklerscorvette.com/corve...1963-1982.html
Those dropped the front a good inch +
I still need to get longer bolts for the rear.
Karsten
Old Apr 1, 2015 | 03:50 PM
Kid Vette's Avatar
Kid Vette
Originally Posted by digitfast10
Help guys
Got a 1973 coupe
Bought 8 in bolts
What I'm I doing wrong
Didn't budge one in
Tighten them so much that the bolt is touching the tire not a good idea
What can I do
Thanks for any advise
Looking at your pic below, I see you tightened the nut on the spring bolt all the way.
The more you tighten the nut the further you raise the car. Use a nyloc nut and just start it on the bolt. Here's a couple pics of my '73.
Old Apr 1, 2015 | 03:53 PM
Kid Vette's Avatar
Kid Vette
Yes you can put a rear sway bar on any C3. See pics I Posted above for mounting locations.
Old Apr 1, 2015 | 07:31 PM
jb78L-82's Avatar
jb78L-82
Correct…a rear sway bar can be put on any vette. NOTE that Kidvette has the CORRECT sway bar using the GM end links, NOT rear aftermarket bars using the end link setup like on the front sway bar….not a good idea since the front sway bar end link setup on the rear bar trailing arm will restrict the movement of the trailing arm adversely in turns….
Old Apr 5, 2015 | 04:43 PM
digitfast10
Cruising
Default Lowering
New pics posted on photobucket
Lowered the bolts to bottom
Got a 2.5 in drop
Need more but will do for now
Got Moog 5758 for front
Mr Karsten can you measure the spring/ do you know how tall so I can compare
I was told to cut the moogs coil not sure
Old Apr 5, 2015 | 04:55 PM
Karsten's Avatar
Karsten
Got a 2.5 in drop
I was told to cut the moots a coil not sure
No way to measure them now as they are installed. I would call Eckler's and ask Tech Support if they know.
Karsten
Old Apr 5, 2015 | 08:55 PM
digitfast10
Cruising
Karsten
Will do thank you sir
Old Apr 5, 2015 | 09:25 PM
wowed777's Avatar
wowed777
Default Lowering
I have been looking to change the bolts from OE to 8 inch to lower the rear. I see people put C-clamps on the spring to help ensure it doesn't slip. I have read many warnings about popping when you release the bolt, kicking it off the jack, etc. I have heard about people putting sand bags under the springs (not sure where). Im very nervous - any advice from people who have done this in a home garage?
Old Apr 5, 2015 | 09:58 PM
htown81vette's Avatar
htown81vette
Karsten
I just put those spring in my 82. This is how she sits now. Actually I think it raised the front end but I like it anyway. The old springs were sagging. But I remember the new springs next to the old springs looked just like your photo.
