paint progress pics
Old Dec 8, 2007 | 10:07 AM
  #101
96vetteLT4's Avatar
96vetteLT4
Default What Gun
What brand paint gun did you use and what size tip did you do the clear in? 1.4?.....Nice job.....G
Old Dec 8, 2007 | 10:42 AM
  #102
'Shifter's Avatar
'Shifter
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
NCM Member '09
That is just friggin' beautiful my man!
Old Dec 8, 2007 | 11:08 AM
  #103
RIISITAS's Avatar
RIISITAS
Great job! Looks awesome!
Old Dec 8, 2007 | 12:11 PM
  #104
LouisvilleLT4's Avatar
LouisvilleLT4
Did these cars have clearcoat from the factory? How many coats of paint did they originally have?
Old Dec 8, 2007 | 02:42 PM
  #105
gator79's Avatar
gator79
I used a devilbiss plus gun and a 1.3 tip
http://www.autorefinishdevilbiss.com/products.php?pg=1
the gun worked great for me
Old Dec 8, 2007 | 02:43 PM
  #106
gator79's Avatar
gator79
yes they had clear from the factory. I am not sure on how many coats of paint but they have a sealer then paint then clear
Old Dec 8, 2007 | 03:12 PM
  #107
Calderone's Avatar
Calderone
Good Job !
i wish i could paint like that !
i never tried anyway
nice nice nice !
congratulations !
Old Dec 9, 2007 | 12:32 AM
  #108
shawn 84&92's Avatar
shawn 84&92
Beautiful job, I hope to paint my wifes MG in the next few weeks, and then move on to the 84. If it comes out half as nice as yours I will be happy. The MG will be my second car to paint.
Shawn
Old Jan 7, 2008 | 01:32 PM
  #109
corvettedan22's Avatar
corvettedan22
Hey two questions for you.
I need some pointers
In order to get the mirror's, door handles and side molding off what is the best way to get your hand in there? I already have the panel off. Do you have to take out the speaker and the box ? Or the center metal part of the door which every is is attached to ?
and
On the rear bumper there is supports, on the lower and upper wings with metal.. Did you take them of for paint ? Or just tape the screw holes and paint up to them?
http://i132.photobucket.com/albums/q.../DSC038162.jpg
Thanks Dan
Old Jan 7, 2008 | 01:50 PM
  #110
gator79's Avatar
gator79
and
Thanks Dan
my 93 is a little different than your 85, I left my outside handles on since I was painting them also. for the mirror I found it helped a lot after I removed the outer glass felt. the wires were a little bit of a pain, just use a coat hanger with a hook bent in the end. my speakers are not in the door so I can't help there. good luck
Old Aug 21, 2008 | 04:53 AM
  #111
samsonb's Avatar
samsonb
Originally Posted by gator79
this is what I did and I don't think you can get it to look any better than it will come out. sanded it with 320 down to the factory sealer, (it had been reapainted and the clear was peeling) then sealed it with epoxy primer, shot 3 coats of high build and blocked it out using guide coat. shot 3 more coats of high build blocked sanded again using guide coat. I allways use wax and silicone cleaner before I spray primer or paint and wipe down with a tack rag. after I was satisfied I sealed the primer with sealer and shot 2 good coats of base. I then shot 5 coats of clear. I could have only done 3 coats but I like the depth the extra coats give it. It layed down slick enough that I will start blocking the clear with 2000 and then 3000 grit. buff with Meguiars diamond cut compound and finish off with swirl remover and ploish. don't skip the epoxy primer stage on any fiberglass that has been repinted. I learned this lesson the hard way on my '71
So, you put down an epoxy primer, then the high build primer, sealer, base, then clear?
What brand/type of epoxy primer?
Old Aug 21, 2008 | 01:50 PM
  #112
c4sailor's Avatar
c4sailor
Looks great. Nice jb. i'm headed in the same direction with my 87 coupe. Dreading the prep but know that is the key to a great result.
Old Aug 21, 2008 | 01:55 PM
  #113
Rob10R's Avatar
Rob10R
Nice...Nice!! Great Job Man!!
