Shell Gas
Old Apr 15, 2009 | 12:04 PM
  #41
MMOCguy's Avatar
MMOCguy
I really haven't notice any difference the few times that I have purchased Shell gas and I have used Shell occasionally in all of my bikes and cars over the years (Which have included a wide variety of vehicles and performance options). The reality for me is that I buy my gas at the cheapest station I can find that I know sells a lot of gas. I've done it that way for years and have never had a problem.
The problem I have with Shell is that the vast majority of their stations are either filthy or their restrooms are "Out of order" or "The key is missing". I don't use the restrooms very often but I refuse to do business with anyone who is so lazy as to shut down the public restroom so that they don't have to clean it at the end of the shift. It happens often enough that no one can convince me that corporate Shell doesn't know about it and still allows it to happen. I have yet to find this with other stations (Even the cheap independants).
Norm.
Old Apr 15, 2009 | 12:24 PM
  #42
5abivt's Avatar
5abivt
I would have to dig up my dyno graphs but on my brand new gsxr 600 that was broken in on the dyno, Sunoco fuel made the room stink like there was no tomorrow and everyone there knew it right away that i was using sunoco. They told me to go fill up with shell and come back. I ran a full tank (spent 40 mins on the highway going bansai) of shell, then topped up with shell again and re-dynoed about 2 ours later.
Sunoco 101.3
Shell 104.7
The smell was different and I 'thought' I could feel a noticeable little more kick in the throttle.
Old Apr 15, 2009 | 12:25 PM
  #43
ShadowC4's Avatar
ShadowC4
i guess i am lucky, i have no shell stations near me. i use chevron in both of my cars.
Old Apr 16, 2009 | 08:13 AM
  #44
Epimax's Avatar
Epimax
Had some bad experiences with Shell years back, and haven't used them since...
Old Apr 16, 2009 | 08:44 AM
  #45
Goldcylon's Avatar
Goldcylon
Originally Posted by rons85
I'm just wondering what Adding Nitrogen to the mix does to the NoX output at the tailpipe. Doesn't seem to me like it could be a Good thing..
Be interesting to do a before/after smog test and see what the difference is.
Vaild question always makes me wonder if this is just another snake oil additive.
Old Apr 16, 2009 | 10:25 AM
  #46
Red Rochester's Avatar
Red Rochester
Veteran: Coast Guard
Originally Posted by floridamale
The adding of the Nitrogen is what I was wondering about also. I would think they would of tested for that, also what overall effect it has on the fule system
Old Apr 17, 2009 | 08:30 AM
  #47
PG-LT4's Avatar
PG-LT4
Originally Posted by PG-LT4
I don’t know if it’s coincidence but I recently changed to Shell in my 96 LT4 and got a check engine light. When I checked the code at Advance auto parts it was a 1418 (I think) and the fellow said that was a dealer only code. He suggested I disconnect the battery to reset the computer and see if it comes back. It hasn’t yet but I haven’t added gas yet either. I haven’t noticed any other differences.
I switched form Sunoco only because the Shell station is closer.
Up date on check engine light.
The next day after disconnecting the battery the check engine light came back on. I still haven’t added gas. After returning from vacation I went out for a spin. The light stayed on. Last night I added about ¾ of a tank of Sunoco 94 and drove home. This morning about half way to work the light went off.
My plan is to run another tank full of Sunoco and switch back to the Shell.
More info to follow
Mike
Old Apr 17, 2009 | 10:58 AM
  #48
rickneworleansla's Avatar
rickneworleansla
Originally Posted by engle1147
A few years back they sold a bunch of "bad" gas that was messing up peoples' cars....100s maybe thosands of cars here in the greater Tampa Bay area were affected over the ordeal according to a local news source. A buddy of mine was one of these "bad" gas victims who unknowingly pumped the "bad" gas into his C5 vette. The gas caused the fuel gauge sender to quit working and had other fuel related issues. The good news was that "Shell" paid for the repairs (~ $1,400 for his car - if I remember correctly)....but what a pain in the a$$. My buddy didn't ever use "Shell" gas after that
The same thing happened in Louisiana in 2004. http://www.thepittsburghchannel.com/...60/detail.html I knew many people who had damage to their cars. I was lucky and didnt use these gas stations at the time. I believe the refinery picked up the bill for the reapirs.
I currently just use whatever big name gas station is closest when I run low. Shell, Chevron, or Exxon 93 Octane only.
Old Apr 25, 2009 | 12:37 AM
  #49
elkprairie's Avatar
elkprairie
I worked for Shell Oil a few year back and was the chemist who blended the additive and who was responsible for the quality of the gas produced at the refinery. I no longer work for Shell and the refinery I worked at is longer a Shell refinery. I am not a spokesman for Shell or anyone who make gasolines but I have retained some knowledge of how gasoline is produced.
Gasoline is a combination of hundreds of hydrocarbons that must pass specific analytical tests as defined by the government. The most important of these is vapor pressure and octane value. If you look at the pump the next time you fill up you will see that the octane value is an average of motor octane value and research octane value. This means the gasoline you are pumping has passed specific tests in a "knock engine" or similar test. In short it assures your that the gasoline that was produced actually ran in an engine and did not "knock" at a specific rpm. The other requirement is RVP or Reid Vapor Pressure. This requirement varies with location based on climate. In short it assures you that your gas cap will not blow off when you open your gas tank. Butane is a great octane increaser but has a high vapor pressure. It is abundant in crude oil but because of its high vapor pressure, to much of it cannot be added in the summer. Other poly-branched hydrocarbons (more expensive to produce) are added in the summer to reach the needed octane value.
All gasoline sold must pass these tests and also others to comply with federal regulations. This means that all gasoline is pretty much the same as it leaves the refinery. However, once it leaves the refinery, usually by pipeline, things change. The two additive are an oxygenate and additive. The most important IMHO is additive. The combustion of gasoline in any engine builds up crude that needs to be cleaned out. The additive package added to gasoline makes sure your engine will stay relatively clean. Each major, BP, Shell, Conoco-Phillips, etc., has their own additive package. When they add it to their gasoline it is called "branded". The difference between the major branded gasolines is minimal. It is like trying to distinguish between the cleaning ability of a laundry detergent such as Tide or All. I can not say this more emphatically. THE BEST ASSURANCE OF A WELL OPERATING ENGINE IS SCHEDULED TUNING/MAINTENANCE AND USING A BRANDED GASOLINE. All the major come up with "better" additives and according to their research they are better that others. This is good as it keeps our gasoline getting better for our engines. However, they leap-frog each other so any branded gasoline is good.
The other item is oxygenate. A few years back someone decided that if you could get more oxygen in your gas it would burn cleaner, ie, less unburn hydrocarbons. The jury is still out on this one and your can find spin-doctors on each side of the issure. There were many oxygenates at first, but most have gravitated to ethanol because it was politically correct. Ethanol is OK but it is terrible on MPG. It simply does not possess the BTU's of gasoline and reduces the MPG you will get from you gas. If you look at the pumps you will sometimes see a higher octane gas with ethanol more expensive than a lower octane gas without ethanol.
In summary, I repeat, THE BEST ASSURANCE OF A WELL OPERATING ENGINE IS SCHEDULED TUNING/MAINTENANCE AND USING A BRANDED GASOLINE. If you pull up to a gas station and find a tank truck unloading, go on to the next station. The tanks are rialed (sp?) up by the trucks and even though there are filters on the pumps, crap can still get through. Stick with the majors and use at least mid-grade gasoline. Remember that your HP is based on your engines displacement and not the octane value of the gasoline. High performance engines usually need the increase in octane value to keep from knocking.
Shell's new additive package is probably good as are BP's and Conoco-Phillips (I used to work for them also) and others. I have invested thousands of dollars in my Corvette. I am not going to feed it cheap gasoline.
Happy Trails,
Don
Old Apr 25, 2009 | 02:44 AM
  #50
Wayne88's Avatar
Wayne88
Originally Posted by elkprairie
IHappy Trails,
Don
Good Post
Old Apr 25, 2009 | 09:18 AM
  #51
realsass's Avatar
realsass
Originally Posted by drmrman
I use shell regularly because it is the closest station to me that sells 93... But In all honesty as long as its 93 its all the same to me... Oh and my car dyno'd some decent #'s with Shell... and with the mods I have still passed the sniff test... So I have no problems with it...
Here in the midwest it is practically impossible to buy fuel without ethanol in it.
Old Apr 25, 2009 | 07:11 PM
  #52
Weav's Vet's Avatar
Weav's Vet
Originally Posted by Weav's Vet
I have to confess here........ I avoided them also years ago but curiosity got the best of me so I have run through three tanks now in my vette and GF has run through four (reg) in her Sebring. She says the car is running the best it has since she bought it over a year ago it's an '06. My Vette, well........ I can't really tell any difference other than it's not running like crap. Maybe there is something to this new blend they are using who knows.
I'm not trying to hype or promote Shell here I'm just stating the facts as they apply to me.
For I don't know how long I've had this lope at idle. I've replaced just about every sensor there is on my LT1 in hopes it would fix it. Checked and rechecked for vacuum leaks. Took apart and cleaned the TB until it was clean as a whistle. BTW, I'm a FSM dummy so I just did it my way. Well, my way wasn't good enough.......the lope never completely went away, it would come and go. I'm on my fifth or sixth tank of Shell (I fore get how many) now and the lope has been gone for about a week and a half. This is the longest time it has been gone.
Like many others have posted here Shell used to be a gas that didn't perform well and I was one of them. IMO it was crap gas! I'm going to keep running the new stuff just because of this lope issue. If it comes back I guess it wasn't the gas.
Old Apr 26, 2009 | 11:04 AM
  #53
larry00's Avatar
larry00
Dang I forgot the sequence for resetting your Idle Air Control but you might want to do a search for it as I found it on this site.
Likely tech & performance.
Any time you disconnect the IAC you have to perform this ritual.
Old Apr 26, 2009 | 11:21 AM
  #54
Weav's Vet's Avatar
Weav's Vet
Thanks Larry, been there done that already.
Old Apr 26, 2009 | 11:44 AM
  #55
Demonic85's Avatar
Demonic85
i hate that ****. So according to Don, if I put mid grade in my DD (4 cylinder) instead of the 87 it will run better and make more power? I thought a tune was required to change that.
Old Apr 26, 2009 | 12:52 PM
  #56
realsass's Avatar
realsass
As long as it is 93 octane I am good! No problems yet. Although I do avoid no name gas stations. But not sure if it is necessary or not.
Old May 7, 2009 | 03:48 PM
  #57
85projectC4's Avatar
85projectC4
Cruising
i know that marine mechanics are very happy now b cuz of the ethanol in the gas.....something about it deteriorates fuel systems, carbs & injection.
To Shell Gas
Old May 11, 2009 | 04:05 PM
  #58
Wathen1955's Avatar
Wathen1955
Originally Posted by onedef92
I add a quart of ATF (auto tranny fluid) to a FULL TANK of fuel twice a year. The detergent package in ATF packs a wallop when blended with gasoline.
Cleans intake valves, injectors, and won't harm your 02 sensors, either. Old Jedi mechanics trick. I've never had a dirty fuel-related problem in any of my vehicles.
Interesting. I add a quart of ATF in my Ford F150 to the crankcase only. Never thought about using it in the gas tank. What are the affect on the catalytic converter and other fuel parts?
Old May 12, 2009 | 10:21 AM
  #59
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
No detrimental effects whatsoever. Won't harm 02 sensors, catalytic converters or any other fuel system components.
Just be sure and add one quart of ATF to a FULL tank of gas and run it all the way to empty as you can (without running out of gas, of course) before refueling to avoid prematurely diluting the mix.
Old May 12, 2009 | 10:37 AM
  #60
c-4 lhozwalte's Avatar
c-4 lhozwalte
ive used several stations around arkansas 66,shell,marshall,and in my experence anything with ethanol makes my c-4 run like crap.in fact one time at a marshall aka wal mart i was filling up a very empty tank and i actually started to notice my car was running rougher and rougher as i put the gas in.needless to say i ended my refuel then.and on another point ethanol only has 70% of the stored energy by volume compaired to gasoline.ethanol is only a way to water down fuel imho.and 10% isnt going to have anything more than a miniscule effect on the environment cause youll have to refuel more often.
