Shell Gas
Old Apr 6, 2009 | 11:40 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
I've only filled up with Shell V-Power a couple of times (since the nearest station is more than 15 miles from my house) but my LT1 really seemed to like it.
Old Apr 6, 2009 | 05:28 PM
Klondike's Avatar
Klondike
I thought Shell was using the Techron (like Chevron) in their gas too! I don't think they are adding any Alcohol to the premium Shell here in Texas, but I don't know about their lower grades. I use Chevron in everything I drive now and they all run better than with the Exxon / Mobil that I had been using for years.
Old Apr 6, 2009 | 06:19 PM
pologreen1's Avatar
pologreen1
might try it?
Old Apr 6, 2009 | 06:35 PM
Pwnage1337's Avatar
Pwnage1337
it SUCKS DICK! i try to avoid every possible shell station.
if i had the choice between goat **** and shell gas, i'd put goat **** in my tank
Old Apr 7, 2009 | 01:06 AM
onefinecar's Avatar
onefinecar
Default Shell gas A-OK
I starting using Shell 93 V power last year because the station is close and the cost is usually a few cents less than the off brands (go figure?). I was putting in any hi-test for awhile then switched over to Shell exclusively. My 88 coupe runs better than before, so I'm sold on it.
Old Apr 7, 2009 | 08:55 AM
PG-LT4's Avatar
PG-LT4
I don’t know if it’s coincidence but I recently changed to Shell in my 96 LT4 and got a check engine light. When I checked the code at Advance auto parts it was a 1418 (I think) and the fellow said that was a dealer only code. He suggested I disconnect the battery to reset the computer and see if it comes back. It hasn’t yet but I haven’t added gas yet either. I haven’t noticed any other differences.
I switched form Sunoco only because the Shell station is closer.
Old Apr 7, 2009 | 08:58 AM
StealthLT4's Avatar
StealthLT4
As for the 10% ethanol comments, good luck finding a station that DOESN'T have 10% ethanol. At least Shell is considerate enough to post it on the pumps.
Old Apr 7, 2009 | 06:43 PM
l1sikes's Avatar
l1sikes
snake oil
Old Apr 14, 2009 | 04:40 PM
WPK's Avatar
WPK
In the old days, Shell gas used to be high in Sulfer (1980s). It came through the Royal Dutch Shell Company in Europe, and definitely had a different mix. I used to avoid it, and when I couldn't avoid it, I could smell it in my car (85 Fleetwood Brougham).
Old habits die hard. I avoid Shell Stations like the plague. However, if they've changed their additives, I'll reconsider. However, if the gas is still sulfery, I'm not sure what you could put in it to make it better
For me, Chevron (or Texaco, same stuff) is what I try to use exclusively.
- WPK
Old Apr 14, 2009 | 05:04 PM
pologreen1's Avatar
pologreen1
I love it you are the shell spokes person, I'll pass on shell gas then
Old Apr 14, 2009 | 05:59 PM
jimmers's Avatar
jimmers
All the Shell pumps up here say there is no ethanol in premium. It's marked right at the pump. I don't know if this is true or not.
For regular it says it contains ethanol.
Old Apr 14, 2009 | 06:20 PM
Weav's Vet's Avatar
Weav's Vet
Originally Posted by WPK
Old habits die hard. I avoid Shell Stations like the plague. However, if they've changed their additives, I'll reconsider. However, if the gas is still sulfery, I'm not sure what you could put in it to make it bet.
- WPK
I have to confess here........ I avoided them also years ago but curiosity got the best of me so I have run through three tanks now in my vette and GF has run through four (reg) in her Sebring. She says the car is running the best it has since she bought it over a year ago it's an '06. My Vette, well........ I can't really tell any difference other than it's not running like crap. Maybe there is something to this new blend they are using who knows.
Old Apr 14, 2009 | 08:34 PM
  #33
larry00's Avatar
larry00
Here goes , I try to use Shell in both my Vettes as much as possible !
Even the 450 HP beast LT 4.
Shell does put it's additives in it's gas and you are more likely to be buying actual Shell refined Gas instead of whatever's available.
You see gasoline is mandated to conform to strict Government standards unless local standards [ like California ] supersede them.
Currently there are 133 different blends of gasoline mostly designer blends for different areas.
American Shell bought back the US refineries a few years ago from Royal Dutch Shell.
American Shell owned production and retail outlets only for about 15 years till they bought the refineries back.
They sold them to RDS in the 80's during one of the oil busts.
I've had several tanks of gas go bad before switching to Shell in just a few months with gas stabilizer likely saving a lot of expense.
Haven't had and problems since switching to Shell but I try to buy where the Premium gas sells [ By the University where the BMW's and Volvo's fill up a lot ].
Old Apr 14, 2009 | 11:45 PM
  #34
Vette Gator's Avatar
Vette Gator
Originally Posted by jadams67
Back when I towed my trailers with gas burning, carburated, 454 Chevy powered duallies, Shell gasoline was the absolute worst gas I could put in it. If you wanted to demonstrate the sound of detonation or "pinging", just fill it up with Shell. Go to any other station, even the cheapest Costco or Wal-Mart style stations and it was fine.
This has been exactly my experience with Shell in my 98 F150 truck (4.2 L V6). Every other brand of low octane swill was fine, but Shell always made that truck ping. I haven't been back since.
Old Apr 15, 2009 | 12:00 AM
  #35
81c3's Avatar
81c3
Heres why I wont use Shell. Shell is the largest purchaser of Saudi crude in this country. Conoco purchases the least amount of export crude of any other company. Thats the gas I fill up with. In fact, I'll go out of my way to pass a Shell station in order to get to a Conoco. Conoco premium is excellent in my 11:1 compression ZR-1 and my 2002 Z06.
Old Apr 15, 2009 | 07:33 AM
  #36
Aquaman92's Avatar
Aquaman92
in Orlando they all have 10% ethanol
Old Apr 15, 2009 | 07:50 AM
  #37
-=Tom=-'s Avatar
-=Tom=-
Yeah I think it's different here for us Canadians as that's the same for me.
To Shell Gas
Old Apr 15, 2009 | 10:20 AM
  #38
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
don't worry about gunk if you DRIVE your Vette. Clean the system by stepping on it at least twice a week. That will keep the valves and pistons clean.
Old Apr 15, 2009 | 10:49 AM
  #39
pianoguy's Avatar
pianoguy
I don't know about their gas, but this is a great ad:
http://www.youtube.com/watch?v=39uqfnW1wS8
Old Apr 15, 2009 | 10:52 AM
  #40
onedef92's Avatar
onedef92
I add a quart of ATF (auto tranny fluid) to a FULL TANK of fuel twice a year. The detergent package in ATF packs a wallop when blended with gasoline.
Cleans intake valves, injectors, and won't harm your 02 sensors, either. Old Jedi mechanics trick. I've never had a dirty fuel-related problem in any of my vehicles.
