SYS flashing
Old Mar 29, 2019 | 11:44 AM
bac22's Avatar
bac22
You're replying to a post that is a decade old...
Old Mar 29, 2019 | 05:36 PM
belairbrian's Avatar
belairbrian
As others have mentioned, I had a battery cable that would work loose. Ended up going to Advance and buying new bolts that hold the cables on. Haven't seen the SYS displayed since then.
Old May 29, 2019 | 09:59 AM
Mgodfrey1938's Avatar
Mgodfrey1938
1st Gear
Default Help!
Originally Posted by 93 Aqua Blue
Thanks for the link Rolla! Am I reading this correctly that I cam put the resistors on each side of the console connector as opposed to pulling the radio out? That radio instal was no walk in the park let me tell you. The unit I installed was a JVC KW-XC777 which is a double din. It is a tight but amazing fit fot the factory hole. The sound is incredible!
I guess I’m late to this post I can’t get the link to pull up on fixing the sys light. Did you have to pull the radio or was you able to fix it with out pulling the radio.
