Engine Problem
Old Oct 4, 2010 | 08:27 PM
RH53's Avatar
RH53
Cruising
Engine problem update.
Finally got my Vette running. It idles smooth, revs good. Engine mechanically sounds good. Still getting a check enginge code 42. I have replaced the ignition control module, distributor cap, and the coil.
I also got a code 33 mass air flow sensor. Found insulation cracked on all 3 wires at the same place. They look liked they had been crimped or something.
I know now that the problem isn't mechanical. I am thinking more of an electrical problem. Probably wiring. Need to do some more checking.
Thanks everyone for your help, I think I am on the way to getting the problem fixed.
If you have any more ideas let me know.
Old Oct 5, 2010 | 02:30 AM
Pwnage1337's Avatar
Pwnage1337
It is amazing that all of this happened at once. Maybe you lost a ground or something that is causing all of these codes to come up? Just throwing ideas out there.
Old Oct 5, 2010 | 02:59 AM
Rick1's Avatar
Rick1
Cruising
Hello RH53,
Saw your message, you may want to check your fuel cap, fuel filter, charcoal canister and all vapors lines, rubber mostly and I understand there is a fuel vapor canister at the back side on the passenger side you may also check, section 6C-17 of manual st-364-91 service manual from GM. Simple as things are sometimes, something to check, even gas in the tank. This may help maybe not.
Regards Rick1
