whats your latest problem
Old Feb 1, 2014 | 12:10 PM
somethingwitty's Avatar
somethingwitty
Cruising
Default whats your latest problem
So my 91 just keeps braking one thing after another, won't lie it's fun to fix it up but something's are just annoying, just the other day my blinker switch handle broke. What's your latest annoyance?
Old Feb 1, 2014 | 01:10 PM
Williamlindsey's Avatar
Williamlindsey
Default windows.
mine is the electric windows, when i got my 91 the passenger window wouldnt work then i replaced the motor now the passenger window works but now the drivers side quit.
Old Feb 1, 2014 | 01:24 PM
DanielRicany's Avatar
DanielRicany
My tune. Lol.
Old Feb 1, 2014 | 01:27 PM
AirForceOne!'s Avatar
AirForceOne!
Front inner tierod and new front brakes.
Old Feb 1, 2014 | 02:23 PM
Red89'-L98's Avatar
Red89'-L98
FL Events Coordinator
St. Jude Donor'13
I need to do my front brakes also. They are squeaky and annoying.
I looked in my FSM with my bad eyes and could not find the torque specs for the caliper bolts. I think I found them and they are 30 lbs. ft front and 16 and 26 lbs. ft for the rear upper and lower. Sounds about right.
Also need to replace my battery negative and ground cable but can not find a diagram of them and have put it off for a long time now. I'm still not even sure how they are run yet, need to find out soon.
Old Feb 1, 2014 | 11:24 PM
cessnaguy1965's Avatar
cessnaguy1965
Default Clutch Hydraulics
Right now the clutch master and/or slave are out of mine. Not too much to worry about now because we have been in winter storage for what seems like forever and a day. Right now we have freezing rain and the winter projects I thought I would get to are now becoming spring or later projects. The snow was fun, but I am more than ready for warmer weather.
[IMG][/IMG]
Old Feb 2, 2014 | 12:30 AM
roadcaqpt's Avatar
roadcaqpt
Battery and frt tires today. Have a base 95 radio an frt speakers do not work need to trbl shoot. My go with a double din Nav anyway !!!!
Old Feb 2, 2014 | 12:36 AM
Axial's Avatar
Axial
A/C slider is only half-working.
Old Feb 2, 2014 | 01:06 AM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Time for new rear shocks on my 91 must be age as it only has 55k miles.
Old Feb 2, 2014 | 01:47 AM
Cliff Harris's Avatar
Cliff Harris
I just replaced the nylon cord in the antenna.
My HVAC system doesn't blow out of the upper ducts. The air only comes out the bottom. I took the driver's side kick panel off months ago but never got to removing the programmer to investigate. I did copy the relevant FSM pages and they're sitting right in front of me on my desk. I have a C68 HVAC system and the FSM page showing the ducts was obviously copied from the C60 section and pasted into the C68 section. They forgot to update a few things...
Old Feb 2, 2014 | 02:10 AM
CRUZNC4's Avatar
CRUZNC4
2022 C4 of the Year Finalist - Unmodified
Shocks, leaky valve cover, driver's seat issue and mufflers.
Old Feb 2, 2014 | 08:45 AM
C409's Avatar
C409
...... Arthritis , bad back , and moderate to severe gaseous emissions at inappropriate times .............
Old Feb 2, 2014 | 10:02 AM
somethingwitty
Cruising
I had just replaced the brake booster which wasn't too bad but had to break my back to get under the steering wheel. I do need all new weatherstripping but I might just save that for the next poor fellow
Old Feb 2, 2014 | 12:34 PM
VeryUnoriginal's Avatar
VeryUnoriginal
Old Feb 2, 2014 | 12:39 PM
VeryUnoriginal
Well lets see... I need to replace more weatherstripping, bleed the brakes, flush the coolant, fix some scratches in the clear coat, replace the e-brake cover and handle cover, repair/replace the leather seats, fix an exhaust leak, fix interior pieces that don't fit right or have fallen off, track down electrical gremlins in the auto climate control, replace front brakes (warped the discs by being a dumbazz), replace the suspension bushings, track down a rattle in the front of the car, etc.
Old Feb 2, 2014 | 12:42 PM
MavsAK's Avatar
MavsAK
I think the ECM is going out, the HVAC system is only half functional (can't turn it off).
Targa Top has cracked further, and the tach still doesn't work.
Valve Cup Seals are starting to go out too I think.
She's had a ton of issues over the last year that I've had to take care of so far. Like a broken rear leaf, shocks, brakes, intake gaskets, bad ignition module, relays, fuses, the works.
Old Feb 2, 2014 | 01:18 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
I could use a furnace in my pole barn but not in the cards this year.
To whats your latest problem
Old Feb 2, 2014 | 01:24 PM
mazdaverx7's Avatar
mazdaverx7
I fixed the wiring for the torque converter control solenoid on my 84 and the trans no longer wants to shift.
On my 94, its the rear carpet section. Its bad and looks like crap.
Old Feb 2, 2014 | 02:03 PM
rad928music's Avatar
rad928music
1. Air Pump Pully shaft Snapped off ( Luckily It happened when I was driving into the Garage for storage this December).
2. Rear Muffler Elimators have rust holes thru them
3. Need new Wheels, as I was informed my rims are bent , causing a slight Vibration (though I suspect they did it when they mounted my new front tires %$*&$ Bastard$).
4. Need new Front Y pip also(I suspect the Pre Cats are Shot)
5. Driver side widow regulator not working
Seems like allot but I haven't put much money in this car since I got it in 2004.
If I don't sell it I should have it all fixed by April and ready to
Old Feb 2, 2014 | 10:13 PM
skyhawk50's Avatar
skyhawk50
My wife......after 40 years of marriage, she should know by now that I''ll never grow up and probably take my last breath in my garage while sorting out a problem with one of the vettes.
