Headlight issues
Old Dec 28, 2015 | 11:04 PM
AgentEran's Avatar
AgentEran
Default Headlight issues
So I have been having this annoying issue with my drivers side headlight. when I turn the lights on or off the drivers side motor keeps running for about 5 sec and the housing is not all the way flush when closed.
Here is a video of what it is doing:
Ive attempted unsuccessfully to troubleshoot this myself and all i can see is that this part here is loose:
Is anyone familiar with this happening, or can help me figure out what to do next?
Old Dec 28, 2015 | 11:16 PM
antfarmer2's Avatar
antfarmer2
if it is a newer one most likely 6 bucks of pucks older one the gear. look on youtube for the video fix
Old Dec 28, 2015 | 11:54 PM
Cliff Harris's Avatar
Cliff Harris
Here's the video you want:
Old Dec 29, 2015 | 10:25 AM
Renfield's Avatar
Renfield
Welcome to the 63-ish percent club.
Old Dec 29, 2015 | 12:01 PM
65GGvert's Avatar
65GGvert
You should add the year of your car in your profile and/or include it in your question.
I"d buy two of these and do both. You can get them from any of the vendors. I just did both mine and the first one took about 45 minutes, the second one about 20 after I had the tools and experience. The gasket will tear if you don't remove it carefully, but you can seal it with Silicone RTV or buy a gasket while you're at it. The pucks on mine were completely dissolved into powder and the gear was worn down, but they still opened and closed. Both continued to run (thump) for about 5 seconds in either direction.
These are for 88-96.
Amazon.com: 1988-1996 Chevrolet Corvette Headlight Motor Gear Repair Kit: Automotive Amazon.com: 1988-1996 Chevrolet Corvette Headlight Motor Gear Repair Kit: Automotive
Old Dec 29, 2015 | 12:28 PM
AgentEran's Avatar
AgentEran
Flying Roof Club..... Check
Limp Headlamp Club..... Check
Old Dec 29, 2015 | 12:31 PM
AgentEran's Avatar
AgentEran
Indeed, I will make sure I do add that to my profile/questions moving forward. Its a 96 LT4.
Thanks for the input, and the link! It is greatly appreciated.
Old Dec 30, 2015 | 07:43 PM
DUB's Avatar
DUB
Originally Posted by Cliff Harris
I do not think I can advise people to use this video. There is a way to do this that makes it so you do not have to remove the headlight bucket assembly and have to set it up and adjust it.
I have done dozens...but to each his/her own.
If you care to know my way of doing it...PM me. BUT whatever you do...do not use a flat blade screwdriver on a Torx headed bolt....PLEASE....because you can make it hard for guys like me who have the correct tools to do the job. AND...using a drill bit (pointed end) to remove a roll pin....that is another one.
I know the guy used what he had....but...that is like me having a video of me taking trees down in my front yard by ramming my truck into them until they fall....does not make it the correct way to drop a tree. Just 'saying'.
DUB
To Headlight issues
