Well high speed stability should not be a factor. I read an article with a quote from John Lingenfelter that said " The C4 is the most stable production car I have ever driven over 200 MPH alot more so than the C5."
I figure he has more high speed runs in vettes than I do so I figure he can be trusted..
My C4 feels unstable at over 150MPH..the back of the car feels very light..almost as if it wants to come around. Ever driven a car with a set of tall rear race slicks and radials on the front down a heavily travelled road? You'd swear the back end of the car is bobbing side to side as you drive down the street. My C4 at high speed feels like a milder version of that.
In the Callaway Sledgehammer documentary video, Reeves says the same thing about these cars...the back end likes to move around during high speed straight line runs...the nose squats and the back end lifts at high speed. Does that sound like a stable high speed car?
There wasn't any jackstands involved in that run, were there??? Lets see, jack up the rear, tcs off, 6th gear run up to redline = 200+++ on the speedo.
BTW cf member ericcer has the dual a/o caliper setup and loves it.
Mate, thats a 1990, they dont have TCS/ASR !!! So that will make it easier...
I totally agree. Everything I've read says that the rear-end of a stock-bodied C4 has a tendancy to get loose above 150mph. That's ultimately why Callaway had Deutchman develop the Aerobody package for the Sledghammer (it certainly wasn't done for cosmetic purposes, althought it does look awesome).
Additionally, it should be noted that the window seals on these cars are pretty much worthless above 150mph too. The negative outside air pressure at these speeds tends to pull the windows outward and away from the seals reducing the generally clean aerodynamic profile of the car, and making for one noisey f*ing ride.
Regardless though, I do wish you the best of luck in getting your car over the 200mph threshold. You've certainly got your work cut out for you.
Oh, and for the record, Sledgehammer produced 898bhp at it's low boost setting. When it made it's record-setting 254.76mph run at TRC, the boost was turned up to produce some 1200bhp.
I totally disagree too. I had my 87 up to 245klms/hr (about 152 MPH) and it was dead stable. Also the Callaway sledgehammer made 254 MPH on "the more conservative of the 3 engines built...being of 898 BHP" and they DID run the car at 254 MPH on the 898 BHP engine. Better go back and read it again mate. The boost on the 898 BHP engine was at full with 2x 22 PSI turbonetics turbos if i remember corectly.If your C4 gets unstable at speed you must have a bad wheel alignment or bugered wheel bearings or suspension bushings.
Sorry, but I must disagree. Been well over 150 too many times with no problems.
If my other corvette was solid as a rock at 245 klm/hr on a not so perfect strech of road, with worn front shocks, i dont see what the issue is. I have only had my 94 up to about 175 klm/hr (about 109 MPH) and it felt more stable at that speed than it did at 60 MPH. So yes, i reckon the C4 with a stock body is a very stable car. So im with you 8388
Kilometers? so he was topping out in 5th at under 120 MPH? somethings wrong here!
Carl Johansson
Originally Posted by SupaVette
A mate of mine, could only get 196km/h in 5th when he hit his rev limiter, he could get no more, and the speed was recorded with gps. If he changed into 6th, then he just started loosing speed
I totally disagree too. I had my 87 up to 245klms/hr (about 152 MPH) and it was dead stable....If your C4 gets unstable at speed you must have a bad wheel alignment or bugered wheel bearings or suspension bushings.
Sure the car is stable AT 150MPH or 152MPH...try 170, 190, 210MPH (if you have the HP)... the thread is about going 200MPH++
Ya someone should tell those uneducated backyard hacks at Callaway to check their " wheel alignment or bugered wheel bearings or suspension bushings" before they run their $400,000 car at 254 MPH <rolling eyes emoticon>
If i was going to push 200mph, I would certainly want a bigger/meatier than stock rotor to help get me slowed down, regardless of how many calipers I had on it.
I would want a proven brake duct cooling system for all 4 wheels regardless of which system you choose. I wonder if anyone has such a system that would hold up to that tremendous wind force.
Mate i gotta ask, what brand/type/size tires do you have on your unstable C4? Solid as a rock at 152 MPH with 255/50/ZR16 Kelly Chargers on stock 87 wheels on my last car, and just as stable with Sumitomo 275/40/ZR17 on the rear, Federal supersteel 595 275/40/ZR17 on the front,all on stock 17x9.5 sawblades. BUT, if i put those Federals on the rear, it did feel a little less stable in the rear at 60-70 MPH, and improved again at around 80-85 MPH. So like the other 2 have said there should be no reason for it to be unstable, and i cant see how you would all of a sudden lose that stability between 150 and 170 MPH.
At 150 my car feels rock solid, the only downside is the wind noise with the soft top!
MAAATTEEE!!!! you should have the top down at that speed!!! That will give you the true wind in your hair feel!! I did 200 Klm/hr with the targa panel off, and that was so loud it was months before i had the nerve to take it off again...
Go take a look at the carter family C-4Bonneville racer. It holds it'ss class record at about 224 (I'm working off of memory) The thing has a huge "box" sticking out the hood - but other than that It is the stock body - no wings extended airdams etc. Calloway is going to talk about "unstability" because it sells body kits!
At 161 MPH my 86 coupe is rock solid - since I'm wearing a helmet the noise isn't an issue. (they won't let me go any faster till I get a parachute - so I guess I need to take it to silverstate to get some straight line big speed numbers!
Oh yah - whoever was asking - it looks like you can make 200mph with about 500 HP - I'll let you know in a few weeks!
Carl "I'll take experience over theory and marketting hype anyday" Johansson
I have GY GSC 275/40/ZR17s (17x9.5" rim) on the front and Bridgestone RE71 315/35/ZR17s (17x11" rim) on the back...maybe my high speed instability is tire related...
Could be mate, when i felt the unstable rear at speed it was like as if i had the whole rear end moving in the car, and all it was is the tires. It felt to me like i had the rear alignment moving each time i changed direction slightly. Swaped the tires and stable as ever.
Also check the rear height. Some C4's left the factory with excessive height in the rear, which would cause a small amount of instability on high speed curves. But this is easy to correct.
