200mph?
Old Feb 13, 2005 | 07:26 PM
Bruce's Avatar
Bruce
Default 200mph?
I am curious what speed will I see at let say 6500rpm in 5th gear?
Car is a 6 speed 3.45 gear, weight about 3400bls and 1000rwhp? I want to know at what rpm in 5th gear before I see 200mph on my car. Since my car will have plentiful of hp, perhaps I could keep it in 6th gear? what are your thought?
Bruce
Old Feb 13, 2005 | 07:37 PM
STL94LT1's Avatar
STL94LT1
Here you go Bruce.
http://www.f-body.org/gears/
Old Feb 13, 2005 | 07:53 PM
Bruce's Avatar
Bruce
Originally Posted by STL94LT1
Here you go Bruce.
The link don't work.
Old Feb 13, 2005 | 08:01 PM
STL94LT1's Avatar
STL94LT1
Fixed
Old Feb 13, 2005 | 08:10 PM
Bruce's Avatar
Bruce
I am cool now. I went to the other thread top speed 160mph. Found the speed calculator there and it works.
Well, look like I will have to keep it in 6th gear to reach 209mph at 6000rpm. Which is alright. Since turbo motor like engine load. So to keep it at 6th gear is work for me.
Bruce
Old Feb 13, 2005 | 08:15 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
If you have a dyno curve, I can figure that out for you.
Old Feb 13, 2005 | 08:17 PM
Bruce's Avatar
Bruce
Very very soon we will be hitting the dyno. Because right now we are still working on the 8 point roll bar and all other misc stuffs.
Bruce
Old Feb 13, 2005 | 09:25 PM
NeedSpeed's Avatar
NeedSpeed
How much HP you got to push 6th to 6k rpm????????
Old Feb 13, 2005 | 10:52 PM
SurfnSun's Avatar
SurfnSun
St. Jude Donor '10
Bruce you will bust 200mph so hard you'll be thinking Aero package, coilovers and 225mph
Old Feb 14, 2005 | 01:53 AM
Rich & Lisa_84's Avatar
Rich & Lisa_84
From: I live at www.domesticlugnuts.com I sleep in PA
Bruce
If your using 275/40/17 tires, I think this is correct...
5th @ 6500 = 180mph
5th @ 7200 = 200mph
6th @ 5600 = 200mph
Hope this helps.
Old Feb 14, 2005 | 04:17 AM
SupaVette's Avatar
SupaVette
A mate of mine, could only get 196km/h in 5th when he hit his rev limiter, he could get no more, and the speed was recorded with gps. If he changed into 6th, then he just started loosing speed
Old Feb 14, 2005 | 04:28 PM
GeosFun's Avatar
GeosFun
I have no facts to support this, but having watched lots of aerodynamic VERY FAST cars at the drags over the years get sideways or flip at the 1/4 finish line, the profile of a C-4 could become something of a "wing" and the car could become airborn at that speed. Be careful. We want to hear your stories!
Old Feb 14, 2005 | 04:36 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Gale Bank's Bonneville car
http://www.bankspower.com/im_superrod_jan04.cfm
Time has a way of erasing memories, but when we saw the Sundowner Corvette run 230 mph and some change, we were impressed. When it ran 240 mph, we went over and looked at it – a long time. The massage was flawless.
Old Feb 14, 2005 | 04:38 PM
LPDesRoche's Avatar
LPDesRoche
Well high speed stability should not be a factor. I read an article with a quote from John Lingenfelter that said " The C4 is the most stable production car I have ever driven over 200 MPH alot more so than the C5."
I figure he has more high speed runs in vettes than I do so I figure he can be trusted..
Old Feb 14, 2005 | 04:39 PM
SurfnSun's Avatar
SurfnSun
St. Jude Donor '10
I know a couple of guys who have hit 200mph in stock bodied C4s. They hold fine. According to a couple of rags the C4 is actually more stable at high speed than the C5.
Old Feb 14, 2005 | 04:40 PM
SurfnSun's Avatar
SurfnSun
St. Jude Donor '10
Damn Lee did we post at the same time?
Old Feb 14, 2005 | 08:02 PM
crkemppainen's Avatar
crkemppainen
well I did 160mph in a stock bodied....actually pretty much "stock" '93.
it was loud as hell breaking loose but the stability was awesome. I suggest you do it and find out, because it was better than sex.
To 200mph?
Old Feb 14, 2005 | 11:15 PM
Photomania's Avatar
Photomania
As you may know, Bruce, a car traveling 200 mph is moving the length of a football field EVERY SECOND! I hope you guys have got a very special driver for that feat. -- Eric
Old Feb 15, 2005 | 12:05 AM
Bruce's Avatar
Bruce
I want to try a 200mph barrier some day, but before I am attempt to do this, first I must get 4 brand new tires and up grade suspension. And dual calipers per wheel setup with 13" rotor.
Bruce
Old Feb 15, 2005 | 10:05 AM
SurfnSun's Avatar
SurfnSun
St. Jude Donor '10
Bruce
Bruce,
Id check into Rippie's Wilwood package or some big Brembos. Ive heard really mixed reviews about that dual caliper setup. JeffVette has the Porsche Brembo system on his ZR1...its a sweet setup.
