Engine Update
Old Feb 14, 2005 | 08:40 PM
bogus's Avatar
bogus
Default Engine Update
Well... things are coming together, slowly!
I have the bottom end in and assembled. Rods/crank/cam/timing are all in.
I have one quick question... how much deflection should there be on the timing chain? I have little or none right now. And I have no reference in my Helms manual (or, at least I could not find it).
Thoughts???
Old Feb 14, 2005 | 08:43 PM
CFI-EFI's Avatar
CFI-EFI
Yours sounds right.
RACE ON!!!
Old Feb 14, 2005 | 08:44 PM
bogus's Avatar
bogus
oh, cool! Then I can finish with the timing cover tomorrow!
Wow... this is progressing!!!
Old Feb 14, 2005 | 10:47 PM
JCAIRE2's Avatar
JCAIRE2
You shouldn't be able to move the chain much when pressing toward the center of the engine, between the gears. Did you upgrade to a double roller minus the plastic gear?
Sounds good so far. Have you tried turnign the rotating assembly over to check it's movement? ave to put a bolt in the crank and use a socket unless you have the correct crank snout adapter.
Old Feb 14, 2005 | 11:30 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Can't wait for the pics.
Old Feb 15, 2005 | 09:16 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Old Feb 15, 2005 | 09:25 AM
rick lambert's Avatar
rick lambert
glad to hear you're gaining on it. with the timing chain issue-very very little-they do strecth over time.BTW-it's been years since I've went completely thru a motor BUT no plastic gears for me.
Old Feb 15, 2005 | 09:35 AM
kwik_ta's Avatar
kwik_ta
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
I think you should be posting progress pics... but that's just me. I also agree with above that you should have next to no deflection in the chain. Everything sounds like it's coming together rather well.
Old Feb 15, 2005 | 09:39 AM
Caboboy's Avatar
Caboboy
with the above. In fact, it should be kind of tight even getting the cam gear over the dowel when you assemble it.
Congrats on your progress!
Old Feb 15, 2005 | 01:29 PM
bogus's Avatar
bogus
Great! The timing gear is on, and torqued!
I will take pics and update progress today!!!
Thanks for all your help!!!!
Old Feb 15, 2005 | 07:09 PM
cv67's Avatar
cv67
St. Jude Donor '05
Sounds like wer'e dropping it in this weekend!
Old Feb 15, 2005 | 07:21 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Great news bogus
and you still had time to respond to all those posts
Old Feb 15, 2005 | 07:23 PM
Brimis's Avatar
Brimis
Good luck, don't forget the pics!
Old Feb 15, 2005 | 10:49 PM
WAMRTexas92C4's Avatar
WAMRTexas92C4
Default On a whim...
Never mind responding to just these posts, even through all of this, Bogus finds time to respond to all sorts of posts! Best of luck to you Bogus, will keep my fingers crossed for you when your ready to turn the key! Just let us know at what time, it can be one of those thought thingies....we all "will" it to cranking right up!
Rob
Old Feb 15, 2005 | 11:57 PM
USAsOnlyWay's Avatar
USAsOnlyWay
Woo hoo I got my ready for ya!
Old Feb 16, 2005 | 01:34 AM
bogus's Avatar
bogus
Tomorrow, the intake base goes on. I will post pics then!!!!
Old Feb 16, 2005 | 09:09 AM
wake's Avatar
wake
Sounds good... So what's T driving around in right now while you have her baby apart???
To Engine Update
Old Feb 16, 2005 | 08:10 PM
bogus's Avatar
bogus
She is driving a 1987 or so Acura Legend. It's her aunts car.
Update for today... I was finishing the torquing of the intake, when I had one of the threads quit... it's the first one on the right bank. It's the closed hole, this is good, the helicoil will dig in better.
next up! A helicoil! yay!
ugh.
Old Feb 16, 2005 | 11:32 PM
USAsOnlyWay
Did you run a thread chaser through before installing?
(It is a thread chaser I am thinking of right?, either way you know what I mean, not really mentally all here right now)
Old Feb 17, 2005 | 12:15 AM
bogus's Avatar
bogus
Actually, I did. In this case, I used a tap. The threads were messy, so I ran the tap down, cleaned it very nicely, I thought. Tested the hole with a bolt and it went perfectly.
The threads died when I tried to torque it.
